Where do i buy good 26650 high drain cells?
[quote=JasonWW]
[quote=RapidLux]
Vapcell 26650 battery 4200mAh 32A 15.33€ |Vapcell original 26650 batterie 4200mAh 4300mah 32A wiederaufladbare li ionen 3,7 V batteries handy mooch HKJ test freies verschiffen|Wiederaufladbare Batterien| - AliExpress Can’t find any review of this. Vapcell seems to rate their cells amp draw somewhat reasonable.
Thanks. Is the Sofirn battery itself “fat”. From the picture it looks about the same a the Shockli.
I have the Sofirn HD 5000mah button top, it’s a normal size cell. Just a tad smaller in diameter than the Shockli 5500. I don’t know about the normal Sofirn 5500mah.
I contacted PLB and got some samples of PLB 5000mAh 26650(the 5500mAh was discontinued)
the 5000mAh cells works well on SP33, SP33 V3, but they are flat top, so they won’t work well on SP70 directly.
If sofirn rebrand these batteries, I am not sure if they will be too fat for the flashlight tube.
What’s your ideas? Do you like PLB 5000mAh 26650 HD cell to be used in SP33 V3 and SP70?
Or do you prefer using 21700 for SP33 series and SP70?
I wonder why PLB would discontinue their best battery?
I’ve never heard of their 5000mah. Do you know if it’s new or maybe currently being sold by other companies?
I was told the sales of 5500mAh is not good, the last inventory runned out in Oct.
PLB’s 26650 batteries are for battery powered cars or for factory. Even if flasholics like 5500mAh HD 26650 very much. The sales is not big for PLB. That’s what I am guessing.
The guy contacted me after I emailed PLB official email address, so I think it’s factory direct. Maybe some dealers have inventory.
Anybody help confirm this “discontinued 550mAh HD 26650 from PLB”?
I want to use the battery with biggest possible capacity, provided the performance is adequate.
I like the shocklii 26650 5500mah and already place another order on AE.Why would they discontinue? Hmmm…probably they come out a new one, much more better…
They don’t mention that on their website. They just show the smaller capacity 5000mah, and the specs for that one are not so great, they show 10A continuous discharge. The 5500mah was 15A, so that’s disappointing.
MTN was mentioned here, but that is a US store and I live in Europe. Is this a legit source? Shockli Battery Store
The batteries are 6.93 euro there and the shipping is 3.06 euro via PostNL in my case. Link: https://bit.ly/34N6yHE
On shops like AliExpress and Banggood almost everything seems to get rave reviews and a lot of shops are called ‘official’, so it doesn’t mean much to me. Then again, this store has a 99.3% rating, and the batteries themselves have the full 5 stars, something which you don’t see very often I think. Any thoughts?
Aliexpress is like eBay, it’s a bunch of independent stores that are all grouped together through a common payment system. The bottom line is you need to be familiar with the particular store you’re buying from if you want to be sure to get the genuine article. Just like ebay.
Banggood on the other hand is an actual store so you know who you’re buying from. They also stand behind what they sell. If they should get a batch of imitation batteries then they will stand behind what they sell and make it right.
A common store for Europe is EU.Nkon.nl.
If you want that 5500mah PLB battery they carry it, but the total cost may be more.
So you have to weigh the cost against getting a fake cell from an Aliexpress store over paying more from a more legit source. Most likely it will be legit. You can usually tell by its size and measured capacity.
Good to know and thank you, I did not know about that distinction.
I live in the Netherlands and do know NKON, and got a protected Keeppower buttontop for my Zanflare F1 there. NKON would indeed be my go to source, provided they have what I want. The shipping depends a bit, if it fits through a mailbox (3.2 cm / 1.26”) the national shipping is only 3 euro, if not it’s 5.
Thing is, that Keeppower battery you mention is 15A, and I’m looking to maybe buy a MF01 mini. That lamp might benefit from more amps (Right?). An obvious choice would be to go for a 21700 battery like a Samsung or Molicell, but I heard it might rattle a bit in a MF01 mini, so that was why I was looking for a 26650 cell.
I don’t mind taking an (as educated as possible) gamble. So if I have made up my mind about the torch itself I might just try it.
Okay, I thought you were interested specifically in that Shockli/Keeppower 5500mah 15A 20A cell that you linked to. It should work well in the MF01 mini, although it won’t give the highest measured output.
If you want a higher drain cell to max out the measured lumens the iJoy 4200mah is a good one.
Looks like most 21700 do fit. Molicel and Samsung make good 21700 cells. If you dont have a spacer, just cut a piece of cardboard to help center it.
The one I mentioned is 20/30A right?
Thanks for the tips. This definitely helped :slight_smile:
Yes,the ShockLi 26650 5500mAh battery fits in the Sofirn SP33v3.
They were sold to me by mountain electronics 2 weeks ago after I received my SP33v3
They were delivered at 3.85 volt and charged to 4.2 volts in an Xtar VC4
A discharge capacity test with a 2.5 volt cut off had one battery a 6183mAh and the 2nd at 6138mAh.
The battery adapter that ships in the SP33v3 box holds a 21700 or an18650.
The SP33v3 uses unprotected flat top batteries but it worked with a button top protected Panasonic NCR18650GA in the plastic sleeve.
The user guide recommends unprotected 26650 and 21700 but the 18650 also works.
On high setting my SP33v3 shut off at 2.80 volts but was able to run on low down to 2.60 volts with the ShockLi 5500mAh battery.
Voltage was measured with an Etekcity voltmeter.
EDIT:I removed the bezel and reflector to take a peek at the LED Star.The bezel unscrewed easily.
They are the same identical battery. They are all the PLB-55 under the wrapper. Here are the brands they are sold as:
Shockli 5500mah
Keeppower 5500mah and 6000mah
Vapcell 5500mah red and 5900mah purple
Orbtronic 5750mah
I had to recheck the max continuous output (from 4.2v down to 2.8v staying under the max rated temperature) of the PLB-55. I was thinking it was 15A, but it’s actually 20A. It can do 30A for about 8 minutes. It’s considered a high capacity cell and not high drain, but it’s a newer design than all the other 26650 cells on the market. Its newer chemistry gives it pretty impressive specs.
(BTW, the iJoy 4200mah can do 30A continuous)
I’ve got the Vapcell 5900mAh (violet wrap) but not the Vapcell 5500mAh (red wrap). I also have the Shockli 5500mAh.
Doing capacity testing and IR resistance testing (YR1030 IR tester), I would say they are the exact same cell (also tried weighing them with a small digital weighing scale with 0.1gam resolution and they weigh very similar)
So I would add that the Vapcell 5900mAh (violet wrap) is also the same cell as the Shockli 5500mAh, and thus likely the same PLB-55 cell internally.
Yes, I think that 5900 was an earlier version that Vapcell did. They rated it a bit too high just like Keeppower did so they lowered the capacity on later versions.
Here is a link on the Shockli 5500mah with a lot more duscussion.
Vapewild.com has the Golisi gold wrap 35A 4300mah for $9.99
I have the Shockli 5500mah. I read somewhere here that PLB might or will discontinue this PLB-55.
Today I wanted to get some Vapcell 5500mah Red since I’m getting some Vapcell 21700 4500mah Red.
But to realize that the Vapcell 5500mah Red been removed from their listing. Checked with Vapcell CS and confirmed out of stock.
Looks like it might be true that PLB might or have already discontinued this 5500mah.
Maybe I will just stock up Shockli 5500mah as spare. And looks like Shockli 5500mah low in stock too as they no longer selling the 6pcs pack.
Check stock at 18650batterystore dot com for the red Vapcell 26650 5500mAh 20A($9.99).
Be aware that these are 26.6mm dia and probably won't fit in some flashlights.
They also have a holiday sale on several batteries,chargers and wraps.
I don't know shipping cost to outside the US.
