Tests and facts will be the bests arguments to demonstrate the leading edge of such LEDs. Records are made to be beaten.
For reference purposes I'd be happy to include 219b's measures in the topic opening table.
Many people wanting rosy tints for flashlights (although many don’t for ultimate sunlight/color accuracy) leads them to the 219B as it’s the only high CRI flashlight-sized emitter that offers it. Many here are aware the Optisolis, several brands of COBs and other products still blow them away in CRI/R9/R12/etc.
Problem is solved with tint mixing so kind of a moot point. Leave 219B behind already. There is plenty of space and diffusion in a lightbulb to not have to consider 219B, ever.
Alright, I’m good with that.
I can confirm the 1600 lumen Hyperikons fry themselves after a few months. I have heard the 800s do not but they should also be a lot less hot. You literally can’t touch them they are so hot.
Literally no one is selling better emitters in good lights, like the FF E07…we are stuck with 219b until China offers better in mass production…I would kill for Optisolis in my lights
Only thing that comes close to 219B SW45 in products you can actually obtain is the SST20 with its crappy 3800k greenish CCT.
That depends on the bin you get. Some manufacturers have been better then others green wise with better bins. The 4000K and 3500K 219B also biase pretty warm if I remember to. I’d kill for some E21A multi-emitter lights. Optisolis is pretty good, but it’s limited current wise, and the E21A has good tint and better CCT flexibility.
Anybody have any experience with Ketra’s A20 and PAR36 bulbs? They have a fully-adjustable CCT from 1400k to 10000k @ >90 CRI. CCT is maintained within one Macadam ellipse (centered on the black body locus?) as LEDs age using a control loop that monitors output.
High CRI RA95 E27 7W COB LED Bulb
I picked up 3 of the 5000K versions, really nice tint and color rendition.
I forgot to mention California’s title 24 lighting requirement makes finding cheap good lights easier. It requires min 80 r9 but the cheap ones like Phillips are usually max 3000k. Took like 2 years for that law to dent the scammy high cri market……of course lobbyists complained…
That’s strict. I like it
I now have a table of light bulbs with the corresponding CRI Grade. I have a lot of data from my spectrometer, but so far the only LED technology to earn an A is the SunLike! Please note the bulbs with a * were not tested by me (like the SunLike).
Help me add to the table by sending me links to high CRI bulbs!
I discovered Sylvania A19 LED bulbs, 3000K. $1.50 at dollar store. They look great, no PWM, and not even warm to the touch.
They seem to have a CRI of 80 and nothing more published. That’s a bad sign.
I really want to make a batch of optisolis bulbs (spot type 45deg) for all around my house. 120VAC
What bulb can fit the nichia optisolis VS35SP36?
What is the general maximum wattage a standard bulb can withstand from LEDs also accounting for the driver?
The best case scenario is if the bulb already outputs at 1S or 3S which the VS35SP36 can change to. And then, I just pull out the original LEDs and place the mcpcb on top.
I have never modded a bulb before so I assume they glue them very well for safety. I don’t mind cutting and regluing or things similar to this.
Yea this seems like a good option to me too. But I haven’t sacrificed one of everything yet to find a good host.
If you’re talking a standard, smooth a19 or a21 shape with a plastic or glass cover then likely 7-10 watts max, about like a flashlight. Older more expensive wavy bases can probably dissipate more heat, but you don’t see those any more. Those big corn shape ones might do a little more but since it’s ultimately going to sink at the base where your power circuitry is, I wouldn’t bet any money unless you’ve got a fan pointed at it. Power circuitry is where most of my lights have failed excluding some crappy chinese sticks (leds and pcb literally burned first on that)
I’m picking up this but don’t have any testing gear, but I can already predict the disappointment because I seriously doubt it can dissipate the heat… 37.62€ 41% OFF|Hohe CRI Ra 95 + E27 Led lampen Mais Lampe 40W AC85 265V Ultra Helle 5500K Tageslicht Weiß 4000LM für Fotografie Video Studio|LED-Birnen & Röhren| - AliExpress
On the other hand since it supports a wider power input maybe it will survive this crazy 125v “green” utility power that kills everything except incandescents around here…Landlord said all the common LED makers told him they will not warranty unless he installed power conditioning…
I've taken the opportunity of some 11.11 free time to update and migrate our original old "High CRI table".
It is now a Google Doc, easily readable and shareable online.
It contains all the numbers and info we have shared here so far, including direct links to the various tests for references. Doing that I realised there was an error with the "Qf" formula, now corrected. Hope you all will enjoy it, and that it will ease readability.
As always, please feel free to make suggestions or corrections.
I've updated it to be up to date of this topic, feel also free to point me any missing info.
May I suggest that instead of having two topics on BLF for a common subject, we unit our energy and efforts towards one community goal? As proposed and already started in this topic, I'm pleased to discuss formula/scale, bulbs, or any other matter.
plastic body :person_facepalming:
will go to trash after some months
Yeah… the only leds that will last long will have the fancy finned aluminum heatsink like Sunlike… the high price might make you balk but considering the price of a heatsink like that + the leds you suddenly aren’t getting such a bad deal.
I have an itching suspicion it’s not worth using anything other than Sunlike even ignoring that crazy high cri unless you’re using disposable $2- bulbs…my halogen bulbs always outlast led and power is cheap here >_<
