I don’t know about today, but I looked into Randys setup at PFlexPRO about a year and a half ago and although he has a professional sphere, his is not calibrated with a proper reference source. He sort of guessed to get it calibrated based on many factory lights specs. This is not the way to do it. A lot of folks used this approach in the past and usually ended up with higher results than what we see with a calibrated reference source.
Nowadays Maukka is providing some nice lights to use as a calibration source.
I think Djozz has bought one of those to check his numbers, but he still uses his original reference source in order to maintain consistency with his older tests.
Here is a quote from Djozz’s SST-70 test
This may mean his 4450 lumen peak is a bit high and output may be a bit lower. So I think it’s safe to say the HT70 output is going to be under 13,000 lumen when measured by any sphere using a Maukka calibration light.
Haikelite is no stranger to exaggerated lumen specs.
Still, with an emitter about the size of the xhp35-hd, but with way higher output, it should be pretty impressive.
I own a good number of PflexPro lights and their lumen measurements are a good bit higher than what I measure with the Texas Ace lumen tube calibrated with Maukka lights. However, since Djozz owns a Maukka calibration light, I trust his measurements of this emitter to be pretty accurate.
I wonder how this light will look like (tint and throw) if the domes on the emitters were shaved. Wonder if any manufacturer can reliably do this.
These Two Protected cells have about a 20amp cut off. I have Eight of the Protected Panasonic/Sanyo. If they are not too long and If this comes in NW as advertised, then I may find out.
No, those cells have a 10A limit. When in series it’s still 10A. (Wait, are they saying the protection circuit is set for 20A? I remember seeing these cells a little while back but the protection circuit was set at 10 amp. Maybe they recently upgraded? If so, then 8 of these cells should be able to do 80A before the protection kicks in. Plus these are cheap. I think the 15A Imalents are like $15 each.)
It’s when they are in parallel that you can add up the amperage. So 8 of those would provide 40A 80A. That is plenty for this light.
Do keep in mind that you get the double whammy of extra resistance due to it being a high capacity cell and extra resistance due to the protection circuit.
So 8 high drain, unprotected cells should produce higher output. If your not looking for max output, then those will work fine.
Jon's protection circuitry used to be 13A, last I seen for the GA cells - I bought as set of 4 of these way back. These newer style/look GA protected cells have been bumped up apparently. Jon @LionWholesale has one of the best PC designs around, and at a decent price - he even spec's the protection IC and FETs right there in the listing.
I agree with earlier posts that the throw is probably overrated. 1500 meters, 562.5 kcd - it's amazingly accurate, not 1510 meters, not 1492 meters, but 1500 meters exactly --- hhhmmmm.
As said earlier, this light is probably re-using one of TA's FET+resistor bank driver designs, so yes - NarsilM is the firmware, and yes - it should be possible to port Anduril to it. If I had time I would do it myself, but I just don't have much spare time lately.
FWIW I contacted Banggood via Live chat and Emma said NW will be available November 28th.Sounds a lot better than December 31st.
“As I could check the product is expceted to be restock till November 28, 2019.”….her grammatical error and all!
Hold on a second. She needs to investigate further! Maybe she is confused about Restocking the light VS. Restocking/getting the NW LED? Then again, the lights[6500K] are Not out of stock so maybe she is right.
“I have forwarded the request on urgent priority bases to our team and they will look into this and you will get the information within 48-72 hours. I request you to please wait for the given time period”.
“We are sure about it, but I have forwarded your concern for more clear informtion.”
