Those buying the LT1 from that site, donāt expect to get it any sooner. AE is selling you a light that is not even built yet or have in stock for open sale for public sale that we know of, (most likely if they do its from the 1st batch, because there is a delay in the 2nd batch due to LED supplier issue, (See post below)
Also an update from the manufacturer came in, the supplier for the Samsung LH351D has a delay in supplying all the LEDs needed, and due to that, there will be a delay in the 2nd batch to be released at the end of the month or later.
How did ppl get it for $50? I ordered it with an SP10S and paid Ā£51.48 ($66.15). I applied the new user discount any other coupons I could including the 11:11 code.
There should be a more accurate manual, and some minor firmware differencesā¦ but with the way these things seem to go, there is no telling what differences you may find.
Yep. There are many examples of that sort of disaster happening. The citrus industry in Florida is threatened with a wipeout because of some disease that they figure was brought here by someone illegally importing some orange tree cuttings. In the past, we also made the problem ourselves by importing a species of something that was supposed to be the cure for some other problem.
Maybe because 3450 mAh is not a round number? I have a bunch of these cells and even after repeated abuse 99 % of them still measure 3450 mAh Ā± 30 mAh. I would have called them 3400 mAh just because but hey. All manufactures mAh ratings are lies if you ask me because the testing is done at such low amperage and measured down to 2.5 volts. The NCR18650GA is my go to when non protected 10 amp and or high capacity cells are needed.
