Meet the novelty everybody’s been waiting for — our compact and powerful Zippy! The first Armytek keychain flashlight is now available for pre-order! Regardless of your sphere of activity, Zippy will become a reliable assistant for anyone who has ever experienced the lack of light. Carry it as a keychain, as an accessory, in your pocket, bag or backpack.
Carry it with you every day, while hunting, fishing or traveling. Thanks to the incredible brightness of 160 OTF lumens and a wide beam angle of 110 °, Zippy will do just fine when an additional source of light is needed.
Count on it in any conditions. The ultrathin and lightweight body — only 9 mm and 12 g — is reliably protected from dust and rain (IP67 standard).
Be sure that the flashlight is with you when you need it. An ultrastrong metal keyring and a removable stainless steel clip ensure that the flashlight is securely attached to your clothes, backpack, or belt.
Forget about replaceable batteries. The built-in Li-Pol 100mAh battery is easily recharged with a Micro USB cable.
I have the Wizard Pro headtorch and I have dropped it smashing the glass. Is it a replaceable part and if so how much is it, and does the glass come out easy? the bezel seems well stuck on.
Hello! We have a new promotion for you!
Make an order for more than $ 120, get flashlight ARMYTEK WIZARD PRO (warm) as a gift! Promocode: WizardPro.
Validity: November 22-24.
How to use:
1.Make an order over $ 120.
2. Apply promo code WizardPro.
3. Write the type of light in the comment( warm light, white light).
4. Get flashlight Wizard Pro for free.
