The Quark Aspheric Lens Kit is HERE.
I've been working on this in the background for over a year. The aspheric lens kit allows you to convert your Quark from a reflector-based light to an aspheric-based light. The white Delrin reflector (machined in-house) helps generate some spill, allowing you to see nearby surroundings while throwing a ton of light down range. This is the tightest beam you can get in a package this small.
Note: This kit will work with older Quarks (non MKIII) if you can manage to separate the head. They are glued shut and can be difficult (or nearly impossible) to remove.
After a month+ hiatus, Ben & I are back with a bang. And we're cleaning the refuse of that bang off our windshields with a certain product that we've hyped in this "Life Hacks" episode.
Winter is coming people. Gear up. We wouldn't steer you wrong.
$50 for a AAA clicky light? I dunno. I’m possibly warming up to it though. Just a quick question. Does this particular 219C have that horrible green tint that I notice on all other 5000K 219C’s? I like 5000K but haven’t seen a 219C yet that looks good at that temp. 4000K looks phenomenal though.
Are you talking about the Preon P1? Mine has a little green tint on the low mode, but at higher modes it is pretty much a neutral white. Unfortunately I don’t have any other 5000K flashlights to compare to. I usually go for 4000K.
That aspheric setup is nice.
But have you considered making an aspheric flooder? Myself I love that smooth flood with sharp edges. And I love the compactness as well.
Good news! We just added a handful of Blue Label Delta Flashlights to the site as well as some Alpha Carbons. Scroll down for the specific flashlights, variants, and stock #s. These are first come so don't wait too long!
Be sure to check out the two NEW Delta Special Edition lights!
Delta Titanium Raw – Radial Grooves In this drop: 5 pcs. Shop here.
Delta Copper Burgess Special Edition – Radial Grooves In this drop: 5 pcs. Shop here.
Delta Spun Electroless Nickel - Radial Grooves In this drop: 5 pcs. Shop here.
Delta Titanium Burgess Special Edition – Radial Grooves
Continuing the Quark legacy was always a priority for Prometheus. Since our acquisition of the Foursevens brand in 2018, we've been toiling away in the off-hours and weekends until we arrived at an iteration that walked the line between honoring the past and pushing forward into the future...with a hefty sprinkling of Prometheus dust thrown in for good measure.
Reliable, dependable, comfortable in the hand and pocket – the new Quark was never going to be the brightest LED flashlight on the market. That's okay. It just needed to be the rightest LED flashlight in your collection.
To kick off the Holiday season we're taking 15% OFF the two new Quark MKIIIs. Just use discount code HOLIDAYME15 at checkout.
In addition to the two new Quark MKIII lights, we've released a handful of new Quark accessories so you can tweak and tinker to your heart's delight. Scroll down to check those out. They're all also 15% OFF using the discount code above.
The Aspheric lens kit for the Quark was another project being worked on almost in conjunction with the new Quark itself. Full respect to the custom flashlight crowd – aspherics are fun as balls.
Although the Quark aspheric is fairly small, it generates a cone that increases the maximum throw by about 30m (from 170m to 200m).
The magic here is in the hexagon-shaped LED die of the Nichia 319A. Where normal square LEDs project a square beam, the hexagon shape is round enough that the beam feels natural and allows for 100% focus. Learn more about the Aspheric in the Install video below.
Save 15% OFF the Aspheric Lens Kit using discount code HOLIDAYME15 at checkout.
Most people prefer a "forward" clicky switch that supports momentary activation. However, the "tactical" forward clicky switch sits proud and you can't tailstand the light. If you did want to tailstand, you had to swap in a new switch and boot...the problem being the short switch is a "reverse" clicky and you can't use momentary mode. Problem solved!
I have yet to meet a Quark (excluding the Quark Smart) that doesn't accept the new tailstand cap, which is designed to snap on easily and can be removed using a small, flat screwdriver.
Save 15% OFF the Quark Tailstand Cap using discount code HOLIDAYME15 at checkout.
It's a poorly kept secret that I obsess about pocket clips. I've owned many a flashlight over the years and found too many included clips to be wholly inadequate. So I set a high bar and went for it. Today we design and manufacture a number of high-end titanium aftermarket clips for other lights. After acquiring Foursevens it was a mission to apply that same standard to designing a pocket clip just for Foursevens lights.
These clips are backward compatible with various earlier Foursevens lights and even include a Quark Deep Carry option. Made from heat treated stainless steel, all clips are designed to deliver: reliable, durable, good retention, smooth pocket engagement, and not damaging to your clothing.
Did I mention they're also 15% OFF for a limited time???Use discount code HOLIDAYME15 at checkout.
Xtar's newest generation of multi chargers do not disappoint. Independent channels means you can charge any battery chemistry (ahem – Quark owners). The VC2S (left) can also act as a powerbank to charge your other devices (phone, etc.) via the USB-out port.
The Xtar shows you how charged your battery is AND estimates the time to full charge. This is my go-to brand of battery charger and I'm pretty stoked to stock their latest iteration.
The Prometheus + Foursevens Holiday Sale continues through Cyber Week with 15% OFF a wide variety of gift options for family + friends. Didn't finish all your shopping on Black Friday? We got you covered. Pop open a second window and check the rest off the list.
Use code HOLIDAYME15 at checkout on all the items you see below to save 15%.
Happy Holidays everyone, and thank you for supporting a maker and the whole team here at Prometheus Lights. We are grateful for this amazing community of loyal customers and patrons.
15% OFF All Foursevens Products
Over the hills we go
All means all. We're slapping the 15% OFF discount on every Foursevens product in the store: Minis, Preons, Quarks – you name it, it's discounted.
Use discount code HOLIDAYME15 at checkout to save on Foursevens gifts
A couple things to be aware of:
We will NOT be getting any new Nickel or Copper Preon P1/P2 lights in the foreseeable future, so if you've been eyeing one but holding back, now is the time to act!
The Patch Hats (360 Headlamp Compatible) are currently on pre-order and as such not on sale. Sorry to disappoint...but that shouldn't stop you from pre-ordering if you fancy a stylish solution to attaching your headlamp to your hat.
Obviously got swept up in the Holiday Spirit and applied the 15% OFF discount to the Beta Flex Arm AND all Beta Flex Arm Bundles, which includes the Beta Black or Beta Brass Flashlight.
This is a nice gift for that someone in your life who could use a hands-free, magnetic, articulating light source. I use these all around the shop and have sold many to mechanics, woodworkers, tinkerers, and craftspersons who need a little extra illumination around the work area.
Use discount code HOLIDAYME15 at checkout to save.
Banker, author, salesman, journalist – whatever their profession, nothing bumps them up a couple rungs like a custom-made executive pen. Add clip engraving and they'll come in for a second thank you hug.
Use discount code HOLIDAYME15 at checkout to save. This applies to all Alpha Pens, including the Bamboo Fountain Pens
Put it in its place. Keep it there. These magnets were originally created to help me keep order slips in place around the shop, but turns out they're perfect for refrigerators.
Magnet force is 4lbs – more than enough for the job.
Some gifts are no-brainers. Got a friend or loved one with a keychain? Kappa QR them! Boom. Done.
The Kappa Quick Release Keychain Organizer is my answer to the jumbled mess that can become a keychain laden with keys, keyfobs, flashlights, bottle openers, rubber chickens (for real) and anything that can loop around a key ring.
Comes in Nickel, Brass, Copper, Titanium, Delrin, Lexan varieties.
We kicked this off last week and we have two days left, which means four more chances for you to WIN.
Hit those links above or below to follow along and get yourself in on the action. Today's GAW goes up soon, so standby. We've already given away a Beta Red, a Beta EN, a Beta UV, a Copper Preon, a Mini Turbo MKIII, and a Beta Green. What could we possibly give away next?
Find out below and THANK YOU for being a part of this community and for supporting a Maker. You are appreciated!
Your early pledge will help us have the strongest possible launch! The more pledges we get today the better chance our campaign will be featured by Kickstarter, so pledges and shares really makes a big difference!
You guys make all of this possible, so I wanted to let you know how much I appreciate your support over all these years. My sincere thanks!
Would you consider sharing the campaign with your friends and family? Even if you don't want a set of earplugs...but like what we are doing...you can still make a (really) big difference by letting other people know. I can also guarantee that you know at least one person with ears, and they will thank you later ;)
Thanks in advance!
Jason
Notes on your BackerKit credit: The $10 credit (for add-ons) will be applied to your BackerKit account after the campaign ends. BackerKit is our fulfillment platform that allows us to manage shipping and also to offer add-ons like extra sets of earplugs, cord, spare foam tips and other Prometheus goodies.
Got Lumens, it would be useful to learn what it is before pledging any money. You don’t provide any description and you don’t provide a link to your project other than “pledge now”. I suggest adding one.
