Hi from Norwich UK
Thanks guys and if Milla Jovovich is on here I’m sure I will have a good time :slight_smile:
Size isn’t an issue really as I used to carry an old 6 cell maglite. I will go and check out the emisar now!
Where might I be able to purchase this if I choose to go with it?
Also, I have some brand new 18650 button top unprotected batteries but I am not sure if they are high drain or not. The D18 specifies high drain. I don’t want to be spending any more on batteries really.
intl-outdoor for the light
What’s the make and model of your batteries?
You can purchase direct from the manufacturer, Hank - https://intl-outdoor.com/emisar-d18.html
kirksherratt,
Goose summed it up before I could write it!
Welcome to the Madness!
Greetings from the North Norfolk Coast :slight_smile:
Welcome!
The Sp36 BLF is a very nice light, (avoid BG and GB if possible, unless you like to gamble)
Could you define how floody it needs to be? The sp36 is a good balance between throw and flood.
Otherwise, get an Emisar D4Sv2
Thank you everyone for the info. Much appreciated! Really like the look of that torch though, great suggestion!
The batteries are unbranded (didn’t know any better) 4000mah 3.7v.
I see they have 30q batteries on there but I have seen them much cheaper elsewhere but if someone has a link that would be great.
Thanks mate, may be see you around sometime!
I wouldn’t trust those batteries if I were you. No 18650 is currently rated for 4000mah, so they’re lying about that.
For batteries in the uk I mainly use either https://www.ecoluxshopdirect.co.uk/ or https://18650.uk/ Both trustworthy sites selling genuine batteries.
I live in Beccles so not far from you.
Have you tried www.flashaholics.co.uk ? They have some Eagtac’s in their sale section maybe what your looking for?
Very fast delivery and service.
I use torchy (seller:big_f_d_d) on eBay for UK, he’s also a member here and does his own tests.
https://eu.nkon.nl/ Is good for EU cells, fast delivery.
You want flood? Jaxman Z1.
You’ll thank me later.
Welcome! Good to have some more folk from the UK on board, there’s a few of us lurking around now.
Like it’s been mentioned, ecolux shop or 18650.uk (join the newsletter there’s 18 - 20% discounts most fridays, or use the BLF10 10% discount) are both good sellers of batteries.
Flashaholics.co.uk are fast delivery (also the code: CPF gives 7% discount).
I prefer 18650.uk over ecoluxshop. Also if you use the code 18650 you get 18.5% off.
I just checked which 18650.uk codes are working:
BLF10 = 10%
18650 = 18.65%
BOO = 20%
iloveweekends = 20%
These all work ok at the moment!
Thank you.
I haven’t tries them so will give it a go. Nice one!
Great thank you.
Don’t really like the manual zoom lights to be honest. Just need very bright flood on a wide area.
Superb, thank you.
Another good shout, thank you.
Wonderful, good man! Thanks.
I almost never touch the “zoom”, and just leave it in wide-flood mode. Nice even blanket of light, no angry hotspot in the middle. But, hey…
Whats the run time on turbo before it has to step down? Also, if, for example it can perform turbo for 2 mins, does that mean 2 minutes each time on turbo or 2 mins in total? I am ideally looking for a long turbo time (heat permitting)
Unno, I never noticed any stepdown, so if it does at all, it’s slooooooow.
I called them out on it and got a refund.
Just ordered some 30q’s from 18650.uk :+1:
