1) The battery is easy to replace.
2) The modes are spaced for my needs. High runtime needs to be atleast 1 hour 30 minutes. Medium around 50 lumens or a little lower.
The problem I find with lights of this type is that they’re unusable for practical use. If the high mode lasts for 30 minutes, its useless for me. Then the medium mode is so low that its as good as not having a light at all. The high and medium modes are important to me.
I hope this light is the first to change the mode spacing.
Clickies are large …but tail e-switch (UF-10 style) would add roughly 5 mm to the length without affecting diameter.
18650S style would carry even smaller penalty but would require a custom MCPCB and therefore limit LED swappability,
There is no way high mode will last an hour or more on a 10180 battery. I was told the drive for 200 lumens on High is because 100 lumens is not enough to sell and BLF members push for more and more lumens. If you disagree, make your voice heard! If there are enough interested buyers maybe it could change…
Personally I think a High ~100LM and Low somewhere between 15-40LM would be good since there is also a moonlight for the really low mode. With such a configuration, Low would be very usable and offer a good amount of runtime, while still having High for bursts as needed, and having moonlight for really long minimal lighting.
I think having a useful middle brightness mode is the most important one to get right.
I have my gripe with the SST-20 and this optics. None of my many C01S is in its original condition, so I do not intent to buy another one. Such a small light needs to have a larger, softer spot. IMO.
My C01S is still in the mail so I haven’t experienced it, but I agree that a keychain light needs a good amount of flood and large spot since it will be used at shorter distances.
100 at high or anything that lasts for an hour and then a 40 at medium is good with me. I know for sure I could use this on my keyring. I thought this would be a twisty. No drain and accidental turn on to deal with.
The keyring would need to be off-centered. I think it would add cost but no self-drain issues (I believe drain could be lower than self-discharge of battery) but I might be wrong about that.
Value?
Full Andruil in a light of this size would be a killer feature by itself.
