Golisi IMR18350 1100mAh S11 (Black) 2019
Official specifications:
Nominal capacity: 1100mAh
Maximum discharge current: 11A
Nominal voltage: 3.7V
Discharge cut-off voltage: 2.75V
Charging cut-off voltage: 4.20 +/-0.05V
Internal resistance: <40mOhm
Cycle life: >800 cycles.
This is a high current 18350 Liion cell from Golisi.
The two cells do not match perfectly. They can deliver 10A, but at 15A they are overloaded.
Conclusion
This is from the new generation of 18350 cells that has good capacity and can deliver a lot of current.
Notes and links
The batteries was supplied by Golisi for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
