Sofirn sp31v2 then
Just get a protected bat as there is no LVP
Sofirn sp31v2 then
I see the word “tactical” and I think “junk”. Just lookit all those “tactical” tulip-head zoomies out there being advertised all over the place. And then there are “tactical” binoculars(!), “tactical” sunglasses(!!), ad nauseam.
Specify what you want in a “tactical” light.
You can search about the difference ‘tactical’ and no ‘tactical’
LOL, they do look like tulip-heads, don’t they? I wonder how many brand names is slapped on that same exact light. Every other light on Amazon it seems.
Here ya go, a nice “tactical” light. Says so right on the tin…
https://www.amazon.com/dp/B073VZZKK5/
Oh, and it’s “military grade”, too! Can’t beat the price, either.
Go crazy…
I’m so sick of the tacticool trend
I was as well, about 4 years ago. Now I have a few nice "tactical flashlights" and can see the benefit of them. I have a Jetbeam TH20 at my bedside, and I'm glad it's a real tactical flashlight :)
Instant access to Strobe and Turbo with a single click. Never thought I would actually like them, but here I am ;)
I second the SP31 V2. I recently bought one and it has been a wonderful light to have. On the low power end I have days and days of usable light, but high power gives me serious room filling light. It also has pretty decent throw so you can reach out and light a decent amount of the path in front of you. For this form factor, it is one of the best values out there.
I don’t have many of these flashlights, the best is probably Olight M2R Warrior (not necessarily the PRO) version!
It has direct access to momentary turbo, strobe (press the tailswitch, or multiple clicks on the sideswitch for constant turbo and strobe), moonlight (click and hold from the side switch) and last used mode (click the side switch)!
Apart from that, check the Klarus E1: direct access to momentary turbo and strobe or turbo or lowest mode. This one uses a proprietary battery, though :zipper_mouth_face: For constant ON, full click the switches!!
Another one, the Acebeam TK18, in which you can access to constant turbo, constant strobe, moonlight and last used mode.
You can also check the RovyVon E300s Angel Eyes a different light, but that has direct access to momentary turbo, constant strobe, moonlight and 2 other settings with pre-established levels!
None of these are below the indicated price, though :zipper_mouth_face:
I have a tactical bandana, and it is cool :sunglasses:
I’ve seen the commercials for those, and they’re great!
A former pilot drops the Tac-Bandana™ off a cliff, and after 30sec of floating down to earth, it’s absolutely undamaged!
Plus, you can freeze it in a block of ice, drive over it, you name it, and as long as you don’t mind the dirt, you can go right to wearing it!
Amazing…
I can’t wait for the Tac-Scrunchy™! :laughing:
I’ve always considered ‘tactical’ as having a bezel with big nasty teeth
Nitecore clone?
Lightbringer
Can you think of a better name for a light that fits my definition?
I’m open. I agree the name means different things to different people.
Astrolux EC01 €24 @ Bangood (even less with BLF discount code), fully loaded with Andúril
:BEER:
- SAM -
Off the self truly tactical, I’m going to say Armytek Dobermann, Predator or Viking. With the head tight it’s strictly on/off high mode. Loosen the head a fraction and you get all the modes. I’ve got one of each and they have all worked well for the last 3 years. Some have claimed quality control issues, I’ve experienced no problems. It’s got the potted electronics, great waterproofing and torture tested. One video showed it dropped of a five story building and towed behind a car at 50 mph where it bounces up and breaks the tail light. It’s bright and takes 18650, 2-CR123A’s, 2-18350’s. Should be tough enough to beat zombie’s all day long.
To me, and I recall tossing in my 2¢ but in a different thread, a tactical light is not an EDC light, but essentially is a simple 1-mode (ie, on/off only) light with rear protruding forward-clicky switch. Silent momentary for flash’n’dash, full click for constant-on. Rock-solid reliable, preferably potted, does only one thing and does it flawlessly.
I got by with a 1-mode ’502 for a long time, and as an EDC light, yet.
So? Something like an L2M with potted 1-mode drop-in would fit the description nicely, similar to the Suefire someone pointed out in your thread.
This is spot on, IMHO. High reliability at a low cost, look at the Streamlight Polytac. I’ll actually be the dissenting voice, though, as I prefer a moderate output. You pop on a 1500lm monster in the middle of the night you’ll be dazzled as well. My two bedside lights both put out in the range of 150-200 lumens, single mode and rock solid reliable. Of course if I were to “need” a thrower I have a a couple right there as well- but those aren’t my go to lights.
Another option for a reasonable cost would be the Lumens Factory Seraph- just make sure to run the momentary tailcap as the clicky version is a little bit recessed.
Yep, my ’502 had… I think it had a 1.40A driver, so don’t recall about how many lemons that’d be. 500? Less?
Or maybe it was a 1.05A driver. Forgot. That’d be… what?… 300lm?
Did me fine for a loooooooooong time.
