Foursevens and Prometheus Current Promotions
Yes, I guess that would have helped if I had mentioned that I was talking about the Preon.
I have been buying more and more 4000k emitters to put in some lights and I now lean towards that temp when thinking about buying a new one.
Thank you.
That aspheric setup is nice. :slight_smile:
But have you considered making an aspheric flooder? Myself I love that smooth flood with sharp edges. And I love the compactness as well.
BTW, is there a new Quark Mini AA on the horizon?
SHOP NOW
Delta & Alpha Flashlights Back in Stock
Good news! We just added a handful of Blue Label Delta Flashlights to the site as well as some Alpha Carbons. Scroll down for the specific flashlights, variants, and stock #s. These are first come so don't wait too long!
Be sure to check out the two NEW Delta Special Edition lights!
Delta Titanium Raw – Radial Grooves
In this drop: 5 pcs. Shop here.
Delta Copper Burgess Special Edition – Radial Grooves
Delta Spun Electroless Nickel - Radial Grooves
Delta Titanium Burgess Special Edition – Radial Grooves
Delta Stonewash Electroless Nickel – Radial Grooves
Alpha Carbon
Not sure I know the UI of the Delta lights
The titanium one is… :heart_eyes:
Alpha Carbon is going to the same page as the Delta lights... have a look
SHOP NOW
Next-Gen Quark MKIII
A Classic, Re-born
Like an old friend
Continuing the Quark legacy was always a priority for Prometheus. Since our acquisition of the Foursevens brand in 2018, we've been toiling away in the off-hours and weekends until we arrived at an iteration that walked the line between honoring the past and pushing forward into the future...with a hefty sprinkling of Prometheus dust thrown in for good measure.
Reliable, dependable, comfortable in the hand and pocket – the new Quark was never going to be the brightest LED flashlight on the market. That's okay. It just needed to be the rightest LED flashlight in your collection.
To kick off the Holiday season we're taking 15% OFF the two new Quark MKIIIs. Just use discount code HOLIDAYME15 at checkout.
In addition to the two new Quark MKIII lights, we've released a handful of new Quark accessories so you can tweak and tinker to your heart's delight. Scroll down to check those out. They're all also 15% OFF using the discount code above.
Shop the Quark MKIII
NEW Foursevens Quark MKIII Aspheric Lens Kit
Mod squad
The Aspheric lens kit for the Quark was another project being worked on almost in conjunction with the new Quark itself. Full respect to the custom flashlight crowd – aspherics are fun as balls.
Although the Quark aspheric is fairly small, it generates a cone that increases the maximum throw by about 30m (from 170m to 200m).
The magic here is in the hexagon-shaped LED die of the Nichia 319A. Where normal square LEDs project a square beam, the hexagon shape is round enough that the beam feels natural and allows for 100% focus. Learn more about the Aspheric in the Install video below.
Save 15% OFF the Aspheric Lens Kit using discount code HOLIDAYME15 at checkout.
Shop the Lens Kit
Watch the Aspheric Install Video
Have Cake. Eat Cake.
Quark Tailstand Cap
Most people prefer a "forward" clicky switch that supports momentary activation. However, the "tactical" forward clicky switch sits proud and you can't tailstand the light. If you did want to tailstand, you had to swap in a new switch and boot...the problem being the short switch is a "reverse" clicky and you can't use momentary mode. Problem solved!
I have yet to meet a Quark (excluding the Quark Smart) that doesn't accept the new tailstand cap, which is designed to snap on easily and can be removed using a small, flat screwdriver.
Save 15% OFF the Quark Tailstand Cap using discount code HOLIDAYME15 at checkout.
Shop the Tailstand Cap
Backward Compatible.
Forward Thinking.
It's a poorly kept secret that I obsess about pocket clips. I've owned many a flashlight over the years and found too many included clips to be wholly inadequate. So I set a high bar and went for it. Today we design and manufacture a number of high-end titanium aftermarket clips for other lights. After acquiring Foursevens it was a mission to apply that same standard to designing a pocket clip just for Foursevens lights.
These clips are backward compatible with various earlier Foursevens lights and even include a Quark Deep Carry option. Made from heat treated stainless steel, all clips are designed to deliver: reliable, durable, good retention, smooth pocket engagement, and not damaging to your clothing.
Did I mention they're also 15% OFF for a limited time??? Use discount code HOLIDAYME15 at checkout.
Shop the Pocket Clips
5th Gen FTW
Xtar's newest generation of multi chargers do not disappoint. Independent channels means you can charge any battery chemistry (ahem – Quark owners). The VC2S (left) can also act as a powerbank to charge your other devices (phone, etc.) via the USB-out port.
The Xtar shows you how charged your battery is AND estimates the time to full charge. This is my go-to brand of battery charger and I'm pretty stoked to stock their latest iteration.
Shop the Xtar Chargers
Just for you...
Prometheus / Foursevens GITD Patches
$10.00
Buy Now
Foursevens T-Shirt (Glow in the Dark)
$25.00
Buy Now
Psi Earplugs
$45.00
Buy Now
SHOP NOW
Week-Long Discount
Last call
The Prometheus + Foursevens Holiday Sale continues through Cyber Week with 15% OFF a wide variety of gift options for family + friends. Didn't finish all your shopping on Black Friday? We got you covered. Pop open a second window and check the rest off the list.
Use code HOLIDAYME15 at checkout on all the items you see below to save 15%.
Happy Holidays everyone, and thank you for supporting a maker and the whole team here at Prometheus Lights. We are grateful for this amazing community of loyal customers and patrons.
15% OFF All Foursevens Products
Over the hills we go
All means all. We're slapping the 15% OFF discount on every Foursevens product in the store: Minis, Preons, Quarks – you name it, it's discounted.
Use discount code HOLIDAYME15 at checkout to save on Foursevens gifts
A couple things to be aware of:
  • We will NOT be getting any new Nickel or Copper Preon P1/P2 lights in the foreseeable future, so if you've been eyeing one but holding back, now is the time to act!
  • The Patch Hats (360 Headlamp Compatible) are currently on pre-order and as such not on sale. Sorry to disappoint...but that shouldn't stop you from pre-ordering if you fancy a stylish solution to attaching your headlamp to your hat.
Shop the Foursevens Sale
Beta or Bust
Award-winning pocket stuffer
Every year the Beta QRv2 is a Holiday best seller. Why? You got me, you'd have to ask everyone who gifted it. If I was to guess, I'd say it's because:
  • AAA battery (convenient)
  • Quick release feature (baller)
  • Three mode (considerate)
All Betas except for the Titanium are 15% OFF through the Holidays.
Use discount code HOLIDAYME15 at checkout to save.
Betas covered under the discount include:
Side note: This is your LAST CHANCE to own a dual-mode Beta Black – as of the next shipment coming in they will all be three-mode moving forward.
Shop The Beta Sale
Weird Flex But Okay
Obviously got swept up in the Holiday Spirit and applied the 15% OFF discount to the Beta Flex Arm AND all Beta Flex Arm Bundles, which includes the Beta Black or Beta Brass Flashlight.
This is a nice gift for that someone in your life who could use a hands-free, magnetic, articulating light source. I use these all around the shop and have sold many to mechanics, woodworkers, tinkerers, and craftspersons who need a little extra illumination around the work area.
Shop the Flex Arm Sale
Get it Write
Banker, author, salesman, journalist – whatever their profession, nothing bumps them up a couple rungs like a custom-made executive pen. Add clip engraving and they'll come in for a second thank you hug.
Use discount code HOLIDAYME15 at checkout to save. This applies to all Alpha Pens, including the Bamboo Fountain Pens
Shop the Alpha Pen
Gift Ideas For You and Yours
Hex Bit Driver Tool Roll
The compact solution to keep things together on your workbench or throw it in your bag and carry your tools to go.
Constructed from Horween Chromexcel leather with a Natural Horse strap and button snap closure.
Shop the Tool Roll
Fridge/Shop Magnets
Put it in its place. Keep it there. These magnets were originally created to help me keep order slips in place around the shop, but turns out they're perfect for refrigerators.
Magnet force is 4lbs – more than enough for the job.
Shop the Fridge Magnets
Gift an Organized Life
Kappa Quick Release Keychain Organizer
Some gifts are no-brainers. Got a friend or loved one with a keychain? Kappa QR them! Boom. Done.
The Kappa Quick Release Keychain Organizer is my answer to the jumbled mess that can become a keychain laden with keys, keyfobs, flashlights, bottle openers, rubber chickens (for real) and anything that can loop around a key ring.
Comes in Nickel, Brass, Copper, Titanium, Delrin, Lexan varieties.
I would love to carry a mini turbo in my keychain but there is no way for attachment. Any ideas?
Also, do you plan to offer more emitter choices other than NW XPL HI?
They are on the radar. Go to the Mini’s prototype page and sign up for notifications.
SHOP NOW
Tis the Season!
Flashlight Fam! We're giving away some free flashlights over on the Prometheus Lights Instagram account and on the DarkSucks Facebook Group.
We kicked this off last week and we have two days left, which means four more chances for you to WIN.
Hit those links above or below to follow along and get yourself in on the action. Today's GAW goes up soon, so standby. We've already given away a Beta Red, a Beta EN, a Beta UV, a Copper Preon, a Mini Turbo MKIII, and a Beta Green. What could we possibly give away next?
Find out below and THANK YOU for being a part of this community and for supporting a Maker. You are appreciated!
Head to Instagram
Head to the Facebook Group
Bought these from the Kickstarter. Tested them with the Texas Ace Lumen Tube calibrated with Maukka lights and Sekonic C-800-U.
4Sevens Quark MKIII QK2A Burst 480 lumens 5359K 0.0007 DUV 83.4 CRI 21.5 R9 63.0 R12 81 Rf 98 Rg included battery
4Sevens Quark MKIII QK2A H 266 lumens 5253K 0.0015 DUV 83.6 CRI 21.2 R9 61.8 R12 81 Rf 98 Rg included battery
4Sevens Quark MKIII QK2A M 71 lumens 5073K 0.0027 DUV 83.7 CRI 20.0 R9 60.4 R12 82 Rf 97 Rg included battery
4Sevens Quark MKIII QK2A L (hidden mode) 24 lumens 4980K 0.0033 DUV 84.0 CRI 21.5 R9 55.0 R12 82 Rf 97 Rg included battery
4Sevens Quark MKIII QK16L Burst 635 lumens 5370K 0.0007 DUV 85.3 CRI 27.0 R9 65.4 R12 83 Rf 98 Rg included battery
4Sevens Quark MKIII QK16L H 367 lumens 5268K 0.0017 DUV 84.9 CRI 25.8 R9 63.9 R12 83 Rf 97 Rg included battery
4Sevens Quark MKIII QK16L M 87 lumens 5115K 0.0027 DUV 85.5 CRI 26.8 R9 61.7 R12 83 Rf 96 Rg included battery
The QK2A has a 24 lumen mode that I somehow landed on but is not easily repeatable. Maybe just an unintentional easter egg in the driver.
The default config on those lights seems to not include the low mode. You would need to change to config 4, 5, or 6 which does include the low mode.
Low(Moonlight) should be around ~1lm
$10 Credit on the Backerkit towards accessories after camopain ends
Psi Earplugs is now live on Kickstarter!
Pledge Now!
Your early pledge will help us have the strongest possible launch! The more pledges we get today the better chance our campaign will be featured by Kickstarter, so pledges and shares really makes a big difference!
Thanks!
Jason: Prometheus Lights
Psi Earplugs
New Kickstarter Launched: Psi Earplugs
by Prometheus Lights
Pledge Now!
Our Kickstarter is live!
You guys make all of this possible, so I wanted to let you know how much I appreciate your support over all these years. My sincere thanks!
Would you consider sharing the campaign with your friends and family? Even if you don't want a set of earplugs...but like what we are doing...you can still make a (really) big difference by letting other people know. I can also guarantee that you know at least one person with ears, and they will thank you later ;)
Thanks in advance!
Jason
Notes on your BackerKit credit: The $10 credit (for add-ons) will be applied to your BackerKit account after the campaign ends. BackerKit is our fulfillment platform that allows us to manage shipping and also to offer add-ons like extra sets of earplugs, cord, spare foam tips and other Prometheus goodies.
Got Lumens, it would be useful to learn what it is before pledging any money. You don’t provide any description and you don’t provide a link to your project other than “pledge now”. I suggest adding one.
I have images in the post. Try kickstarter link to read or the web site here.
Edit: I've corrected the problem with the link in the post, Thanks for the headsup.
Hi Everyone,
Just a little heads up.
Foursevens has located some new unsold MKII Quark bodies.
They are up on the site.
First come first served. Once they are gone, they are gone.
Enjoy
Foursevens Quark Bodies Here
pic link
pic link
pic link
SHOP NOW
19% OFF DISCOUNT...BECAUSE COVID19
Not even joking
This thing.
As I write this, all of California is under "stay-at-home" orders. I know many of you are in similar circumstance. I don't know what the other side of this thing looks like, but I feel very confident that we'll get there sooner than later if we stick together, stay in touch, and look out for one another.
As you can imagine, things are quiet at the shop. We've put a temporary stop to warranty claims, the crew is safe at home, and thought we're still taking orders online I can't guarantee fast turnaround on shipment. Heck, I can't guarantee what's going to happen to the business, given the general uncertainty over the length of this thing.
This thing.
That said, we will stay open throughout and ship when and how we can.
We're also running a 19% OFF promotion on ALL BETA FLASHLIGHTS* and ALL FOURSEVENS LIGHTS.
You want the discount code? Here it is:
COVID19
Thumbing our noses at this thing while putting product into the hands of our people. Can't stop won't stop. Use that code at checkout and save 19%.
It might not seem like the right time to be making a flashlight purchase. That's okay. Totally get it. To be honest I have no idea what to expect over the coming weeks. Low sales? No sales? Guess time will tell.
On the other hand if you need a good emergency flashlight or a good backup to your emergency, maybe this deal comes at the right time. If it helps give you and your family even an ounce of peace of mind, I'll feel better for it.
I also encourage every one of you to seek out ways to support local and small businesses. This bailout package is NOT going to ensure they all open at the end of this thing. Because no one knows when the end will be.
Buy a gift card.
Do takeout from the restaurant that is still open.
Find a way to help. This country is run on the backs of small businesses and it is clear that they only way they have a chance of making it will be if their communities support them.
The 19% OFF is effective immediately, no set end date. Sorta like COVID19.
If there's anything I can do to help any of you during this time, please don't hesitate to reach out. You've been here for us through all the good times – we're here for you during the bad.
TELL COVID19 TO SUCK IT
*Does not apply to Beta Titanium lights
30% OFF RECHARGEABLE BATTERIES & CHARGER
As if you needed another reason to love rechargeable batteries...
Many of you are (rightfully) thinking of emergency kits, stocking up on essentials, etc. Batteries should be on everyone's list. But stocking up on disposables does NOT cut down on trips to the store.
Rechargeables do.
I've marked this Battery & Charger Bundle down 30% so you all can stock up. Basically you're getting it at cost – I'm not making money on it.
Choose between AA or AAA. Get them charged right away, and store them in a labeled container so you know which are charged and which are not.
STOCK UP
Just for you...
Mini Turbo MKIII
$65.00
Buy Now
Stor-A-Cell Carrier (AA/AAA/123)
$5.00
Buy Now
USB Flex Charger (Li-Ion & NiMH)
$15.00
Buy Now
