Off the self truly tactical, I’m going to say Armytek Dobermann, Predator or Viking. With the head tight it’s strictly on/off high mode. Loosen the head a fraction and you get all the modes. I’ve got one of each and they have all worked well for the last 3 years. Some have claimed quality control issues, I’ve experienced no problems. It’s got the potted electronics, great waterproofing and torture tested. One video showed it dropped of a five story building and towed behind a car at 50 mph where it bounces up and breaks the tail light. It’s bright and takes 18650, 2-CR123A’s, 2-18350’s. Should be tough enough to beat zombie’s all day long.
To me, and I recall tossing in my 2¢ but in a different thread, a tactical light is not an EDC light, but essentially is a simple 1-mode (ie, on/off only) light with rear protruding forward-clicky switch. Silent momentary for flash’n’dash, full click for constant-on. Rock-solid reliable, preferably potted, does only one thing and does it flawlessly.
I got by with a 1-mode ’502 for a long time, and as an EDC light, yet.
So? Something like an L2M with potted 1-mode drop-in would fit the description nicely, similar to the Suefire someone pointed out in your thread.
This is spot on, IMHO. High reliability at a low cost, look at the Streamlight Polytac. I’ll actually be the dissenting voice, though, as I prefer a moderate output. You pop on a 1500lm monster in the middle of the night you’ll be dazzled as well. My two bedside lights both put out in the range of 150-200 lumens, single mode and rock solid reliable. Of course if I were to “need” a thrower I have a a couple right there as well- but those aren’t my go to lights.
Another option for a reasonable cost would be the Lumens Factory Seraph- just make sure to run the momentary tailcap as the clicky version is a little bit recessed.
Oh yeh, for poking around in the dark, like going down the basement steps without the bother of turning on the light (and waiting maybe forever for the damned tubes to flicker their way to staying on, ugh) I just grab my WW E03 with diffusion film to light the way. Plenty bright, maybe even too much so with the 14500, even heavily diffused.
Alas, the E03 (Xeno), has M/L/H mode order, so by the time I’d click to low, any semblance of night-vision is already gone.
Point is, just a little light, even heavily spread out, is often more than enough.
Agreed, bullet proof, always works, boring tacticool less features. I’ve got one Solarforce with a 1.5 amp XP-L V6 led and it always works. Boringly simple, very tactical and on the night stand near the Glock 21 duty pistol. Seraph is also a quality P60 light. In fact I E-mailed them to consider the 21700 format and picking up the Solarforce L2 style left void by Solarforces departure from the business. I would encourage other to do the same as they seem interested in the battery format.
Mmmm, with rumblings of Sofirn reviving the ’502, I was initially enthused. As soon as I heard the tailcap was likely to have those damned thumb-guards… pass. Evvvvveryone wants ’em to tail-stand. Fooey.
At least the switch on the ’502 was slightly protruding, enough to still activate easily. Not quite L2 style, but close enough.
Guard-ring around the switch, with or without cutouts? Nope, not for me.
I’m quite critical Foursevens given my experience with my new 2aa quark Mkiii but they still did a LOT of things right. The tail switch is excellent and offers easy and reliable access. For those that would need tail standing they include a snap-in plastic ring so no worries either way.
Overall, I like the old Surefire style for “tactical” lights. Push for on, release for off. Virtually nothing to break or go wrong.
We’re in agreement on that, but what would you call it if not “Tactical”?
Since the manufacturers don’t seem to get it, how do we get their attention?
I like extra lumens in the new lights but why all the gimmicks, like a lockout? I think that most of us are smart enough to unscrew a tail switch. That’s the main reason I don’t like the new Olight. It doesn’t have to be my primary SAR light either.
SS strike bezel, like Solarforce L2-B5, not ridiculously aggresive
2 or 3 modes max, low and high with instant access to strobe, but it isn't in the modes loop
Side switch for modes changing? Maybe it would be good, I like my Jetbeam PC20, it has instant strobe access after holding the side switch for 1s. And strobe isn't too fast, and has couple of faster and slower blinks
IP68
Red or orange color parts
Rubber protective parts, like in my PC20, this ring near to a tailcap (still can't find a name for it)
Hmm you’re right, but then modes changing with forward switch requires some dark moments…like in my life
And side switch would be only for modes changing, but maybe it could be only for strobe? 1s hold for strobe and 3 click for beacon? It would be cool, and raised switch retaining ring like Emisar has - so if side switch, then only for strobe and beacon, and with raised retaining ring and illuminated.
So… It’s 0 dark 30 and someone hits you in the head while you’re walking to your car. As you stumble to your feet and realize your flashlight is in the wrong mode… he hits you again… hmm
It’s really bright
Comes with an aggressive crenelated bezel (removable) that can tear chunks out of whatever its used on
Instant strobe when flashlight is off, by holding down mode button. When flashlight is on, hold down mode button for strobe
Defaults to the highest level every time it is turned on.
