Nice new release. There are very few multi emitter lights that use an efficient constant current driver. Too bad it uses a built in battery. That’s a deal breaker.
Yeah basically you are looking at a 12LED that pulls 35A and your runtime is zero. Supposedly there is no limit to how much direct driver one wants but at some point it becomes highly redundant to label how many lumens something does if the cells is empty in 2 seconds.
Floody reflector lights this bright dont work all that well for actual real world use. Reason being is that the bright spill floods the foreground with too much light and blinds you. TIR lights are much better in this respect.
This light would have been way better with the KW CULNM1.TG LEDs.
Dont worry if it’s not bright enough… Next year I’m making a single cell light with 35000 lumens 2 seconds turbo runtime 10kcd. Built in fire extinguisher. 1300mah battery… and best of all it’ll only cost two kidneys.
Just because it has a poor skirt cap to protect the refill, it’s far from my interest. I am not against the possibility of charging, but a single rubber cap makes it too exposed to weather events
I’ve tested some Nightwatch lights before and their lumen ratings are exaggerated a bit. I’m guessing their 9,900 lumens is more like 7,000 lumens. Until someone on BLF measures with a calibrated lumen sphere, I’ll take it with a grain of salt.
I look at it as a mini MS18. Capable of depleting almost all of its entire fuel supply in a brief brightest burst for size, if I want to. I ordered one, for starters.
I tested the Nitecore TM9K using the Texas Ace Lumen Tube calibrated with Maukka lights and a Sekonic C-800-U spectrometer. Output taken at 2s from turn-on.
Nitecore TM9K
Turbo
8,190 lumens
6637K
0.0017 DUV
69.7 CRI
Blue light relative amplitude 1.00
-25.2 R9
44.2 R12
65 Rf
96 Rg
included battery
Nitecore TM9K
M4
1,879 lumens
6247K
0.0057 DUV
69.0 CRI
-34.7 R9
41.2 R12
66 Rf
95 Rg
included battery
Nitecore TM9K
M3
446 lumens
6109K
0.0072 DUV
69.2 CRI
-37.1 R9
40.0 R12
67 Rf
95 Rg
included battery
Nitecore TM9K
M2
124 lumens
6121K
0.0066 DUV
69.1 CRI
-35.9 R9
40.5 R12
67 Rf
95 Rg
included battery
Nitecore TM9K
M1
33 lumens
6543K
0.0025 DUV
70.0 CRI
-26.6 R9
41.7 R12
66 Rf
96 Rg
included battery
Note: the TA lumen tube gives lower readings for mules and extremely floody lights. I think we can add 5-10% to the measured output of this light.
The light looks good and it is extremely floody with a somewhat noticeable hotspot at the center. Makes for a great indoor light especially for large spaces. The output is really limited by the 5000K battery in it. I think it is a 50E or M50T rated at 10A continuous. If they used the brand new Samsung 50G rumored to have 15A continouous, it should be able to hit 10k lumens. I'm sure if it used a high current battery like the P42A or 40T, it can do 12k+. I know this is meant as a tactical light but I just wish it could tail stand. I don't like the CCT and tint though so probably won't ever use it as a tail stand light.
Thanks, SKV89 and bmengineer for updated data and teardown pics.
I ordered this light when it was first announced by Nitecore, I was excited when a major quality manufacturer decided that Everyman can have 9,000 brief burst lumens from a single 21700 cell flashlight. I got mine January 6th, and I really like it a lot. I showed it off to many people, and a few people actually were sufficiently impressed with its size/power ratio to immediately order it.
It is kinda neat to see seven topic threads on two forums for an exciting light bumped up weeks later at the same time to receive data updates .
