Nice mod on an ancient light! The D10 is rather large (for 14500) and boring looking but the piston-drive is special.
I rather like how the black frp / clear mask of the driver looks.
I don’t hate the black/clear but IMO it’s kinda boring looking compared to purple (it’s what oshpark is known for after all).
I think it’d look better with a hatched ground pour instead of solid Cu. If I run across any more hosts and need to order more boards I think I’ll update it so it’s prettier.
I also don’t like how hard the silk screen is to read with this color scheme.
This is the first reflector in which I’ve actually been pleased with the luxeon v2, LOVE the emitter behind a triple optic but IMO the beam from a reflector was lacking… Not in this case, it’s perfect!
As to the plain body, I’m really hoping to find a Balder HD1
Awesome! I am willing to do that in the one I bought a while ago, but haven’t ordered the driver yet!
Did you just swapped the driver or did you have to do any trick inside the pill (because of the wires,etc)? If that is the case,fo you have any photos that may help the mod?
Thanks in advance!
Great work!!
Does it just like smaller reflectors? It’s fantastic in my D25C.
I think it has to do with the reflectors depth:width. I tried them in an S2+ with OP shorty 20mm reflector and an Olight S15 (also very short overall but Ø=20mm) and both of them were ringy and had a pretty strong tint shift from spill to Corona to Hotspot.
The D10 reflector (also Ø=~20mm) has a much better depth:width ratio, I’d guess that’s why.
Also note the centering ring setup of the D10 keeps the reflector quite high off the 3535 emitter (originally XR-E).
20mm TIR lens won’t fit?
Modded a Astrolux EC01.
All with Liitokala Lii40A Battery
Stock: 4300 Lumen
AWG20 Bypassed: 5300 Lumen
Dedomed: 4900 Lumen (Dedomed like ZozzV6 did on the XHP70.2)
Nice little HotRod
Sadly the LED is colder than XHP50.2 3B which have 5000K.
This flashlight is advertised and sold as 5000K, i think it’s 2A Tint with 5700K.
I would bet the issue is centering height, then, if you’re getting rings. That’s been my experience, anyway. What’s really odd to me is the tint shift, as I never see that at all with the Luxeon Vs and the V2s are a close second there, at least in the lights I’ve had them in.
Nickel Boron?
Actually I’ve been reading on that just today and thought it would make a good surface finish for a flashlight. It’s interesting to see it was actually used this way. Could you please share your thoughts about it?
NIB = New In Box
Ah…not that interesting then.
Yeah, I like your idea better
You can now enter your modded lights in the Old Lumens Competition too.
Not much of a mod, but here’s what I just did. We’ll see what it does tonight.
A $0.59 bowl from Target. I think it would be better if the bowl was a little more translucent. I drilled it out with a 2-1/2” hole saw and trimmed the edges a little with an Exacto blade.
LT1 on level 3, getting a little darker here….
You’re right (and you’re not). A white or translucent bowl would reflect more light, and maybe even let some light through. On the other hand, the green gives it that good old times appearance. In daylight it looks very pretty.
Totally agree here. I've done 1 or 2 mods in somewhat similar fashion but they never come out look'n as good as yours, Catnap! It gives me ideas though of using straight single strand wire instead of the coated 30 AWG multi-strand wires I had been using.
I sprayed the underside of the bowl/shade last night. That does make the illumination on the table worksurface brighter and removes the greenish cast. I have picked up a couple of other colors as will drill them out sometime today. Photos later.
One of those 3 for $1.80 flashlights, pimped with rngwn’s warm LEDs
Direct driven, three AAAs. 110mA each LED
Nice, that must be about 200 lumen of extremely pleasing illumination.
