FW3A Troubleshooting / FAQ
This puts me back into the low and high mode (2 step mode). I tried the reset thing, but it didn't work.
Never mind. I tried your instructions again and it worked. Thank you!
Cool.
I think it’s a bit too easy to accidentally do 4 clicks and change the settings. :disappointed:
It is :D
I recently bought an FW1A to see what all the fuss was about.
Unfortunately the one I got seems to have quite serious issues. I’ve spent a few hours trying the solutions mentioned in this and other threads, but I just can’t get it to work consistently.
Where the problem is now is that during tightening the head it will flash to show contact, but when fully tightened not respond to the switch or do anything at all. Sometimes it will instead treat it as if the switch is in a locked-on position and ramp up to max and stay there. Other times (more rarely) it will come on in a low fast flickering mode, then ramp down and then up to max and stay there.
I originally thought I had a faulty tailswitch but now think it’s to do with the internal tube - this may be either not making contact, or contacting both the driver and the retaining ring at once. Sometimes hitting the head on something will make it work as it should for a short while, but it always seems to end up with the same issues again soon afterwards.
I’ve tried re-orienting the driver in the head a few times. I can see the flat notch on the circuit board, but I can’t find anywhere that matches up to this in the inside of the head so I’m not sure there is a ‘correct’ orientation for this. Does anyone know if this has been changed for the FW1A? The driver does seem to move slightly (<1mm) during tightening the retaining ring or during use, so I’m not sure it is properly seated.
Can anyone recommend any other things I should be trying to get this working, or will I have to send it back?
I think my original type tailswitch occasionally double-click bounces, giving me an unpredictable number of clicks and going into the wrong mode.
I’ve had way too many occasions of ending up in some unwanted mode and having to figure the darned thing out yet again.
So:
Asking more about the new-design tailcap — is it available, is it lego-able to the original tube, and is its switch reliable?
Check continuity of the black tube. Some others have used sandpaper to make sure the tube has bare metal on each end.
Thanks, I gave each end a light brushing with very fine grit. This has helped insofar as the light now consistently behaves as if the switch is always on, instead of sometimes stuck on and sometimes stuck off. There must still be something else to fix get it working properly though.
your switch may be misassembled
esp if you took the tail cap off
see other posts for the ‘nubbin’
it can fall off unnoticed, or be off center
would make the switch appear on all the time
wle
Thanks for the tip. Just did it. I was having some slight flakiness if I didn’t tighten down thoroughly. Seems better. Kudos! :beer:
Ok, I’ve just tried this. The ‘nubbin’ seemed well seated and the metal plate centered well and all working ok physically. Unfortunately, after re-assembly the light is back to generally not switching on at all again, apart from the brief flash while the head is first screwed on.
Still no Contact…
I will put it in the list of other failures of venders to think twice about dealing with. Email, messaging here, No replies.
Great concept, Poor execution of product and customer support. Yes I do understand that there is a limited number of people behind the scenes, but that is no excuse of leaving any customers out in the cold.
To those that come to the defense, it was poorly planned and executed hence 35+ pages of people having problems. Yes I am sour on this transaction with Neal.
35 pages yes, that does not mean it’s tons of people having problems. In fact, most got it figured out. The rest do seem to be defects of some sort. A certain percentage of all products will have defects and manufacturers know this.
Also, this light is sold by Banggood, Lumintop and Neal. Not just Neal alone.
It was your automatic ramping that seemed most worrying. That would indicate a short to ground somewhere in the driver, inner tube or switch area.
Since your issue seems quite tricky, I would suggest removing the head and battery and just testing the switch circuit. I show it here.
If we can get this part of the light working, then we can focus on the head. Make sure your clip is not preventing the tail from fully tightening down.
Oh yeah, please tell us what battery your using. Unprotected flat top I’m hoping. Button tops may or may not fit.
Maybe this is the issue? The driver is not seated down into it’s groove?
Have you tried to gently rotate the driver to see if you can find the little notch to make it drop down into?
The groove on my FW3A is only about half as deep as the driver is thick, so it doesnt “fully” drop down flush, but it does lock into position.
I’m not very familiar with this particular model of light either but I think it uses the same basic head and driver design as the fw3a.
IMHO, the one HUGE problem in this whole endeavor was the cost cutting measure of NOT putting a ring in the tail cap so that it doesn’t fall apart when removed. That was just… not good judgement. The result was a huge number of problems. And now? Guess what—they’re now doing it, after all this.
I personally don’t have a problem with the unsecured tail cap parts. I always remove the front to change batteries & in fact, doing it from the battery side is a pain because it loosens the clip. So the encouragement to go from the front is the right idea.
Thanks for the suggestions.
I have tried rotating the driver and it didn’t seem to fall into any groove. It only had freedom to rotate less than 180 degrees though and I may have missed it - I didn’t remove it completely as this would have required desoldering the leads and I thought that would stop me from being allowed to return it if it does come to that.
Anyway, the continuity test with the tail section indicates that this is where the problem lies. Depending upon how tightly it is screwed down, and how it is assembled (whether I include the metal spacer between switch board and tailcap or not), continuity is made or is not. Clicking the switch doesn’t change anything in either situation.
I may just have a faulty switch.
You can easily take the switch apart, just remove the tape. Maybe you have some oxidation or something under the dome.
I’m not sure what you mean by the metal spacer between switch board and tailcap.
I’ve tried taking the switch apart already, and couldn’t see any sign of oxidization either on or under the dome - I really can’t work out what the problem is there.
The spacer is a slightly bent flat ring that was seated between the switch board and the rubber boot with the ‘nubbin’ in. I haven’t seen any sign of one in the FW3A dissassembly videos so perhaps it’s a new addition?
I wonder if we can get more resistance in the switch by taking off the spring-steel dome on the switch and bending the 3 wings slightly inward.
