use three power supplies connected in series as input power supply, a complete powr supply comes out, enough for battery charging(it is risky,be carefully when do that)
https://www.aliexpress.com/item/4000282551930.html
First customer review(China not included, they got devices one month ago)
twitter:@KutilDomaci
[We're doing a stress test. Powered by small brick 32V / 2A. We pulled over 80W from it]
RD6006:https://www.aliexpress.com/item/4000282551930.html
RD6006 feedback:
Specifically, RuiDeng’s RD6006 is already similar to an adult device, but more important is the reasonable design - stick the power supply inside and close it all in one.
thank you for making the test video
RD6006 review
[in general I really liked the design and functionality of the device.The package was packed firmly, there is one uncomfortable temperature wire for the battery(I didn't expect you to install the temperature sensor cable it this way)]
Can two RD6006 be used in parallel to achieve 12A?
no , it can’t , we don’t allow that , output must be isolated…
What’s the advantage of this over a much more powerful DPS5020?
1.you can see the screen is bigger, we change the screen from 1.44 inch to 2.4 inch
2.the settings will be much easier because we add a keypad, if you want to set output value, you just need to spend a few seconds
3.add battery charging terminal, for more detailed information, you can see the videos on the youtube, we uploaded a lot
4.PC software has been changed a lot, now it is not only a data recorder, you can upload firmware for new function and use calibration function
as for other functions, it takes much time to introduce, you can check the product detail page or watch the videos
detail page:70.89€ 20% OFF|Rd rd6006 rd6006w usb wifi dc dc spannungs strom abwärts strom versorgungs modul buck einstellbarer wandler 60v 6a batterie laden|Multimeter| - AliExpress
youtube channel:https://www.youtube.com/channel/UCy73jJ5-ZqhPzT7wJ6KTIaw?view_as=subscriber
RD6006 customer feedback:
set RD series and DPS series on the same panel
RD6006 link:https://www.aliexpress.com/item/4000282551930.html
