The input connector and a temperature sensor come with the RD6006. There is also a fan on the back of the RD6006.
A CR1220 battery is required to back up the time and date. The battery is not included with the RD6006 or the case. The supply works without a battery but doesn’t remember the date or time.
The S06A case includes a 50mm case fan and power board for the fan.
Drop is specified as >10% and > 1V. The instructions say to set the input to 62V for 60V maximum output.
Thank you so much for your message and your support
I am so happy that you like it
for big screen, there is not plan now , we are planing to make higher power for RD series
in fact, 2.4 inch , it is ok, for now
you can share your experience for RD6006W, If there is any problem, we can talk it here
1, you said input connect ? yes, we have in the box
2, input voltage must be higher 1.1 times than output … input 21V , the output max will be about 19V
[Excellent. Received quickly. Impeccable packaging. Exceptional. Perceived quality excellent. Works perfectly. The quality of this product and really good compared to the price. I am very satisfied.]
RD6006 feedback
Fine! Packed - beyond praise! Everything works. The accuracy of the installations at altitude. I recommend products from this manufacturer. Not the first purchase already. One minor minus - there is no watch battery. but it is not essential https://www.aliexpress.com/item/4000282551930.html
RD6006 feedback:
Great packaging. Excellent DC / CD converter - on its basis you get a very convenient and functional power supply. Description corresponds to 100%. I’ve bought it several times in this store and never disappointed. Great seller! https://www.aliexpress.com/item/4000282551930.html
safely packed in a styrofoam box.tested some voltage & ampere measurements using Uni-T UT139C, the accuracy is within specs, enough for my needs. overall i really satisfied with the product. thank you RD Tech.
[Packed perfectly, in a foam box + dense cardboard box + porous sealant. The product is fully consistent with the description. Checked, everything works great (very accurate and stable). Many thanks to the seller! I recommend!]
RD Tech, I have some feedback for you.
I’m interested in your products. I’m not your customer yet but I intend to become one.
I keep reading your threads…but I’m about to stop. “Hey, someone just reviewed our product” is not an interesting message - I’ll find reviews when I want it. And I feel they waste my time.
“There is a new product”. “We have a sale”. “We just changed product X so it does Y”. These are the kinds of messages that I’d like to see.
Hi
Is there any way to retrieve Sense + and Sense - for the output voltage of the RD 6006 for more accuracy ?
I wish if you could provide for us a partial diagram or show us how to sense remotly the power . this will make the efficiency of RD 6006 much more interesting
