If you really don’t want to go down the back e-switch route, I think the UI you posted is quite good (I completely overlooked it, my bad!). There are some caveats though, as I understand:
You can’t switch the light on in moon or low mode via the side switch from complete OFF. You would have to carry the light in Standby. But then the rear switch does not act as a momentary anymore (you have to click it once).
You don’t have momentary high from rear switch when you are using the light in a lower mode, instead it cuts off power completely.
Those are some griefs I have with it.
I admit these are probably very me-problems and don’t concern anyone else. To me though it’s kinda ugly that the rear switch does something different depending on what mode the light is in right now (from OFF it is momentary then ON, from ON or Standby it does nothing then it cut’s off power) - that’s why I dig the dual e-switch designs I mentioned. No matter if the light is on or off, rear switch is always Turbo.
Completely agree, with a “tactical” style light you absolutely need the same function from OFF every time (preferably to 100%). That comes from either a tail+side e-switches or a tail-switch only design.
Klarus and Acebeam both use tube-in-tube. I can confirm this for the Klarus XT2CR and the Acebeam T36. Olight does so on the M2R but opted for proprietary batteries with an aditional pole in most of their other models.
Can’t we have a dual switch 21700 with usb-c recharge and power bank. The highly praised Wuben TO50R would have been a perfect light if it had the power switch at the tail instead of to the side. The switch is so freaking difficult to find it the dark that I don’t use it often. It is pretty much perfect in every other way.
I like the light design in post #1. However, being a tactical light, ditch the on-board usb-c charging port and put a ~6k emitter in it. I’m not looking to make sure the leaves on my boxwoods are color correct at night with this light…
Potentially interested in a dual switch 18650 (currently only have AA for dual switch), especially if:
Focus on efficiency over max output (I don’t want 10 seconds of burning my hand, I want 10 minutes of efficient bright output)
TIR rather than reflector (lets save size where we can, and I usually prefer the beam pattern with TIRs over reflectors anyway)
High CRI (my low CRI lights are almost never used at this point)
The logo or design aren’t too gaudy
Option to default to or start in low output (starting in high is a pain if you’re trying to use it around the house)
Sublumen moonlight mode
Emisar style flashing pins (realize this is a reach, but I would love to see them become an industry standard)
My personal preference for UI is a bit different than what is proposed in the OP at the moment, but that’s because part of my focus is on keeping it simple if I want to hand it to someone for use. I would almost separate it into “rear switch is on/off/momentary, front switch is cycle up/cycle down”.
I’d start with something like (assuming lockout is not needed):
Rear switch:
Tap: Momentary On (brightness i.a.w. mode memory settings)
Press: On / Off (forward clicky)
Default: Low (Mode Memory = Off)
Alternative: Last used mode (Mode Memory = On)
Side switch:
Hold = Cycle up
Click + Hold = Cycle down
Double Click = High mode
Triple Click = Change between stepped modes and ramping mode
Quad Click = Blink out voltage
Mode memory On/Off
Hold side switch + tail switch for 5s
This would also keep it similar to Anduril (but a bit simplified), for if someone wants to switch back and forth (assuming we don’t want to go full-blown modified Anduril).
I bought a Sofirn SC31B a couple weeks ago. It’s my first single-cell 18650 flashlight. I like it a lot, but the other night I took it outside before turning it on, and when I eventually needed some light I started feeling the tail end for a switch — but this flashlight does not have a tail switch!
Some flashlights with side switches MIGHT be shaped in such a way that it is easy to find the side switch by feel, but not my Sofirn SC31B. More than once I have found myself rotating this light in my hand more than one revolution, trying to feel that side switch, and eventually giving up. Then I hmust take my eyes off what I was looking at so I can locate the switch visually.
To be fair, the Sofirn SC31B is not (and was never advertised) as a “tactical” flashlight. But now that I have had these experiences it is clear to me that a truly tactical flashlight must have a foolproof tail switch — so the user can easily find it and turn the light on without wasting any time feeling for a side switch.
Bottom line:
Any “tactical” flashlight should (in my opinion) have a simple and reliable clicky tail switch that (hopefully) turns the flashlight on at full power from off. As long as this switch works 100% of the time, having an additional side switch to control modes, etc. would probably be a desirable extra.
Is there any reason the light couldn’t have two very different UI modes? One more enthusiast and one more “emergency” oriented? I know what can be stored on the controllers is a limitation for some lights ( that’s the reason Biscotti exists IIRC).
Mech tail switch and side e-switch is definitely a no-go for me no matter what. Having to change the position of the light in your hand for powering it on/off and changing modes is awful compared to just a single tail mech, or even better the Acebeam/Olight-style dual e-switch.
Their two mode groups aren’t always that different but several recent Klarus, Olight, and Acebeam have something like this too. Skilhunt has two completely different UIs in their newest 14500 and 18650 lights.
Seems like it depends on what kind of driver and controller are used though, I know some of the Attiny chips have limited… memory, I guess? Or some other limitation on how many operations a UI can have.
Two very different UI’s should have two different lights. I carry one tactical light and one duty light. My tactical light has high/low only with a tail switch only. It should really be on/off only. Small 18650 format. I’ve used it with quick tail tapping for all sorts of stuff. Like signalling “I’m over here” to building searches. The “duty light” is really in the tacticool category. Having a tail on/off only switch. I set its mode with the side switch and then on/off as needed. It’s more of a work light in 21700 format for lots of long use. This one does traffic control, searches, reading in the car, etc. For the O @#$% moments it’s an attached weapon light.
Don’t over think it. Robust, simple, always works.
