As a preface, this requires decent equipment, decent skill, attention to detail and ultimately might result in your lantern being damaged beyond repair from either inappropriate use of the equipment or incorrect execution.
Even though I performed the mod successfully I give you no warranties. If you blow a hole in your PCB or one of the ICs you did it yourself.
So to mod your LT1 to charge from C to C cable you will need a following:
- Mod wire. Thinner the better. Best would a magnet or enameled wire of 40 awg or above. Like this I have used a scrapped parts of a litz wire. If you are looking for some on the cheap then if you take apart any relay, small electric motors the chances are that you will find an enameled magnet wire that will work.
- 0402 or 0603 resistors like this we need 5.1kOhms +/-20% so technically any value between 4.1k and 6.1k would work. Not sure where you could source those on the easy. If buying from anywhere buy at least 10. They are super small so if you even think about sneezing around them they will disappear. They should be cheap enough, probably pay more for shipping as compared to the hardware.
- A soldering iron. Preferably something direct heating and has decent tip on it. Standard chisel won’t work. I worked with one like this this
- Tweezers that are angled something similar like this . Any other tweezer will do as long as you can grab a 0402 comfortably but the curved ones will make your life easier. Preferably another pair of tweezers
- other soldering equipment solder, flux, wick, wire cutters, IPA, possibly brush etc
- RTV preferably clear but a red one will do.
Once everything is gathered you can start.
You need to lay the driver flat and secure it. The wires should be long enough to allow you to pull it out, and secure so that it doesn’t move (you can use double sided tape to whatever it will be laying on). Kinda like this (borrowed from djozz from here) Any movement during soldering will be your enemy.
Note here. When I did mine I didn’t remove any of the wires going to the main leds but you can. If you do so then you will have much better access to what you want to do it. However I didn’t feel like doing so since there is a lot of wires and most of them are black.
Here is the data sheet for the USB C connector used in the LT1. What are you are looking to do is connect CC, pins A5 and B5 to A1, A12, B1, B12 through the resistor. Here is pointed out what is what on the actual picture USB-C .
Find a decent spot for the resistor, I initially put them more or less like this .
With the resistor position set, cut you enamel wire so that you don’t have deal with the whole bunch of it.
Strip the ends of the wire using your soldering iron. What I do with enamel wire I put bunch of solder on the tip of the soldering iron and then stick how much I want to strip and leave it there for couple of seconds.
Take the resistor and tin the ends of them. Similarly put a bit of solder on the tip and then touch to the end of the resistor so a bit sticks.
Now comes the hard part. Apply as much flux as you are comfortable with to the connector pin. Put as much solder as you can on the pins that you will be using. If you get some pins bridged it’s not the end of the world. Use the wick to clean it up.
Once you have the pins tinned, it is pretty much solder everything in place. What I aimed to do is the following. What you can do with the magnet wire is that once it is solder in place you can “snap it off” by keeping it taught (but not pulling strongly otherwise you might lift a pad) and move it back and forth until it comes off. Since the resistors are not attached to the board you will have to support them using another pair of tweezers or something pointy.
After about 45min of swearing and wishing that your hands were smaller and listen to your parents and didn’t sit so close to the TV you will end up with something like this . Even though it is ugly it is type of situation that if it is stupid then it works.
Clean with IPA and brush gently.
Visually inspect to make sure that there are no visual shorts etc.
If everything looks good then proceed to testing.
What I did is, I plugged in the usb-c charger to the wall, gave it couple of Mississippi, unplugged from the wall, then plugged in into the LT1 without batteries. Since the USB-C provide significant power they generally have enough energy stored in the input and output caps so that they can hold up the its internal and LT1 circuitry for few seconds. By doing this you limit the incident energy that is available so if there is anything wrong, there might be a puff of smoke but you shouldn’t destroy the connector or the board.
If everything is alright then you will get a flash, that the LT1 has power, and the green LED that the batteries are fully charged.
Once you have everything tested and confirmed that it works, apply the RTV to the area to ensure that the mod doesn’t get damaged physically. What I did is gave a squirt of the RTV and gently pressed into the board, tried not to smear it around.
Hope that helps you guys. If you have any questions then let me know, will do my best to answer them.
