Lexels driver compilation
On the 811A I can not even change the color of the digits what was possible in the 811 one
so they made the more expensive version worse
Since I got a D4SV2 I’m a big fan of Andruil with 1634 and RGB LEDs.
Do you have any plans to migrate some of your drivers to that architecture eventually?
some new ones
Acebeam X45 the latest gen with programming port
21mm replacing all previous ones
What are the features of this 21mm driver of yours? What software is compatible?
its now combined 1/2S
2S without AMCs using small FET and up to 4 13 Ohm resistors
Programming pads for firmware update from battery side with flash key
Is there a demand for X45 drivers?
Maybe the stock drivers tend to go bad due to a flaw or something?
BLF Firmware
a bit more Output 13.3V 15A
Do your drivers include necessary software? Why are there no feature descriptions for your drivers? Are the pictures expected to tell the story?
This is just one of more driver related topics
I have plenty of information in the other topics, this one should list just an overview for current models
I have also a complete topic with guide for the 2 mostly used firmware, of course firmware got their own Topics especially from Toykeeper
Try this thread. [Sale] 7. batch DD 1S/2S Bistro HD OTSM/NarsilM/Anduril drivers 12-47.5mm size S2+, C8, H03, MT03, Q8 Clicky or E-switch
Software is installed and tested.
Ok thanks.
See edited post above. That’s the order thread.
Lexel, do you have any plans to migrate some of your drivers to that architecture eventually?
Coming soon
15mm 2S
Sponsored by MascaratumB
was not here listed for some reason
Acebeam K30 (with mirrored tail board)
Thanks for your work Lexel! Just to let people know, this will be used in the LT Tool 25 and in some other 2xAA (soon to be 2x14500) flashlights !!
Thanks again and I’m sure other people will grab these too :wink:
I think this will be the final version
about 3.5 hours went into the design
Can this driver be used to drive a UV LED in a Tool 25 with 2x 14500? Will it regulate the current until the batteries are depleted to 6V?
Hi Lexel,
Will this work with Acebeam K30 GT with SBT90.2 LED?
The FET has no current limitation, the small current resistors have current limiting function but no regulation and are only useable with 6V LEDs
No regular 6V XHP
