“REVIEW”: Wuben TO50R = 21700 battery / 2800 lumens / 4 x LH351D / High CRI / Powerbank function [Pic Heavy]
28 posts / 0 new
MascaratumB
MascaratumB's picture
Last seen: 3 hours 25 min ago
Hi BLF,
This my review of the Wuben TO50R flashlight!
The flashlight was kindly sent by Wuben, and no other compensation was given besides the flashlight and accessories.
Some time ago, Jelina from Wuben reached to me and asked to make a “pass-around” experience. http://budgetlightforum.com/node/68269. It didn’t work well, but it resulted in another option: http://budgetlightforum.com/node/68467
My sample was not included in the 3 “participants”. Still here is my review of this incredible flashlight!
You can also find more information about it in these reports/reviews and also on the original GB thread: http://budgetlightforum.com/node/66052
clemence: http://budgetlightforum.com/node/68525
maukka: http://budgetlightforum.com/node/69364
GENERAL SPECIFICATIONS
Body Colour: Black
Material: Aluminium + Stainless steel bezel
Emitters: 4 x Samsung LH351D 5000K High CRI
Lens: Quad TIR Optic (not Carclo)
Battery: 21700 (can take 18650s)
Charging: In-built Micro USB Charging Port
Switch: Dual Side E-Switches
Max runtime: 191h (at 1 lumen)
Max beam distance: 146m
Max output: 2800 lumens
Candela: 5329cd
Waterproofness: IP68 (2 m underwater for 1h)
Impact resistance: 1,5m
Low Voltage Warning: Yes (detailed below)
Reverse Polarity Protection: Yes! (but not specified)
Working Voltage: 2.8V – 4.2V
Working Temperature: -10ºC to 60ºC
Other Specifications
Intelligent temperature control: monitors flashlight temperature and adjusts the output accordingly to control temperature.
Constant current control: enables continuous and stable output.
Powerbank function: with the custom USB cable, this flashlight can be used as Powerbank.
FLASHLIGHT & ACCESSORIES
The box of the Wuben TO50R flashlight is a standard Wuben box – white / blue / black – with some specifications of the flashlight shown both in the front and the back of the box. Through the front plastic window we can see both the flashlight and the custom USB cable.
So, let’s see what this box brings to us: the Wuben TO50R / 1 pocket clip / 1 lanyard, a 21700 Li-Ion 4800mAh 17.76Wh 3.7V protected battery (slightly raised button top), a custom USB to Micro-USB cable, 1 holster, 1 plastic adapter for 18650 batteries, 2 spare o-rings, user manual, warranty card.
NOTE: Before seeing how the flashlight looks and works, it must be said that the TO50R results from a cooperation between the BLF member _ the_ and Wuben manufacturer!
The User interface and even the “to support 4x emitters and 21700, added magnetic tailcap and the deep carry clip, defined the functionalities + output levels, and re-designed the whole UI, etc.” are of _ the_ ‘s authorship.
Also, this is a flashlight designed for outdoor environment and for activities (such as photography) that imply good light control and good colour rendering.
The FLASHLIGHT
The Wuben TO50R is composed by 3 main parts: head, battery tube and tailcap. Unlike its sibling Wuben TO46R, the TO50R is not glued! Yuppie!! This seems to be a pre-requisit from the above mentioned collaboration, serving either for modding or repairing the flashlight.
In the front part, there are “2 e-switches”, along with the model indication and the Wuben logotype. In the back, we find the USB port, covered by a rubber cover and, in the battery tube, we find the indication for the correct battery placement (battery positive pole towards the flashlight head).
The anodizing of this flashlight is great, with no flaws and it allows a good and smooth grip and feeling while handling it. It has a classy matte touch.
It also provides good ergonomics due to its design, even if the dual e-switches may be hard to find sometimes! But that’s a minor question within such a great flashlight!
Let’s see this by parts!!
As mentioned, the head can be separated from the battery tube. It has some cooling fins in the sides to help with heat dissipation. Still, in the back we find the “caution” signal just below the bezel. The driver is protected by a black plastic piece, to avoid shorts and to prevent the circuits. Instead of a spring it has a solid brass button coming from the board.
Looking from above, we see the 4 beautiful Led under a custom quad TIR optic. As far as I know, there were some complications with the initial batches of optics, but they are now solved!
Above the optic we find a Stainless Steel bezel with some grooves and a thin white o-ring to prevent water from entering.
However, there is no glass lens what seems to be a bit ¬_risky_ due to scratches or other “incidents” that the optic may suffer. Let’s hope nothing goes wrong with it!
Below the optics, we can see the thick copper MCPCB, with some thick wires soldered into it and the 4 Samsung LH351D 5000K High CRI Leds. The MCPCB is held in place with the help of 2 screws. As the bezel and the TIR have to be rotated to tighten the bezel, these screws are fundamental to avoid breaking the wires and to prevent displacements of the LEDs.
Last but not least, a perspective on the custom TIR optic. This is also a fundamental part for the great beam this flashlight offers, with no artifacts or shifts.
What about the battery tube?
Well, first, it is not reversible! It has some linear knurling that doesn’t affect the grip (nor positively, nor negatively). Actually, it could be a little bit deeper, like the Zanflare F1, to help on a better grip!
It has grooves for the pocket clip in the top and in the bottom, what is a positive thing. The upper threads are non-anodized, while the lower ones are anodized. Both top and down edges are non-anodized as well.
The threads are very well machined, no chips anywhere, and they are trapezoidal or square, allowing a smooth fitting and threading. There are sealing o-rings in both parts.
The photos below also show that the upper wall, near the driver is thicker than the lower one, what is also good for heat dissipation.
Last but not least, the tailcap. On the base of the tailcap we find the serial number and also CE and the Wuben website address.
Inside, there is a thick gold plated spring, a retaining ring (with 2 grooves to be unscrewed) and the magnet that makes this… a magnetic tailcap!
About the magnetic power…well, I’ll let the photos below speak for themselves Big Smile
Ain’t this funny? Big Smile When this sticks to something it is hard to retrieve it! So, a warning to all your magnetized cards and devices, ok?
How about the dimensions and weight of this flashlight?
Well, carrying a 21700 cell inside makes this a heavier flashlight. It is a heavy cell, so it will be felt. However, it is not unbearable in a pocket specially if clipped to the pocket’s flap.
Also, this is not a big chunky flashlight. It is bigger than some 18650s, but not much bigger than all of them. But, it is not the smallest quad flashlight, too.
The ACCESSORIES
USER MANUAL
Lets start by the User Manual. It is written in 3 different Languages (English, Deutsch and Chinese). English is well written and explains pretty much what we need to know about this flashlight.
The points addressed in it are: Warnings; Package List; Product Features; Product Operation (Structure, Installation, Constant on Mode, Flash Mode, Instant Turbo, Lock out and unlock, Discharging; Charging, Low Power Indication); Parameters; Maintenance; FAQs; Warranty Policy.
Not all the information about the light is there, so a quick check on Wuben website is a complementary way to get more information!
CUSTOM USB CABLE + CHARGING
As mentioned above, the Wuben TO50R comes with a custom USB cable that allows to use the flashlight as powerbank. The Cable is 24cm long.
It is composed by a USB in port, a USB out port in one part of the cable, and in the other part it is has a micro-USB port.
USB in + Micro USB can be used to charge the battery inside the flashlight, while USB Out can be connected to other cable to charge another device or battery.
During the charging process the “Power Switch” (lower) will:
- blink RED – when the cable is plugged
- constant RED – when charging (at least below 3.8V)
- blink BLUE – when charging (at least above 3.8V)
- constant BLUE – when charged
Please note that when charging the flashlight can be used in Low mode, even it only the head is connected to the charging cable.
HOLSTER
The holster included in this package is very nice and will built. The TO50R fits well and tight in the main “pocket”. It also has a side pocket in which we can carry a spare battery or even the charging cable.
In the back, it has different ways to be attached to a belt, backpack or others. A “D ring”, a belt loop and also a velcro “loop” that can be used to carry it!
BATTERY
The included battery is a slightly raised button top 21700 Li-Ion 4800mAh 17.76Wh 3.7V protected battery. It is a long battery that doesn’t fit my chargers (Opus BT-C3100 and Nitecore Digi D2).
It seems to be a high drain battery but I cannot make an appropriate test of it to confirm.
It arrived protected by a blue plastic sheet to prevent accidental activation and draining during shipping.
I must also say that this is my first 21700 battery so I have no others to make comparisons, so far.
BATTERY SPACER
As mentioned above, this flashlight can also take protected and unprotected 18650 batteries that still are more common and easy to get. For that Wuben included a plastic spacer that takes this type of batteries to stop them from rattling inside the flashlight.
Here it is with an unprotected Sony VTC6 and a protected 18650 Wuben battery.
POCKET CLIP
The pocket clip included in this package is one of the deepest and strongest clips I’ve had! It can be reversed and be used towards the top or towards the bottom of the flashlight.
It allows a true deep carry, but as it is very narrow, it may cause some friction with the fabric it clips to.
Below you find some examples of how it looks like when used in different situations.
Also, it allows good retention. It can be used to indicate where the switches or the USB port are located, in case you align it with those.
USER INTERFACE,OUTPUTS and RUNTIME
I said it before, that this flashlight has a special UI design by _ the_ .
Being a flashlight that can be used in photography, all the UI operation is quite simple, using single clicks or press & hold. No multiple clicks here Silly
Both switches are used to operate this flashlight. The lower switch will be called here “Power Switch” and the upper one “W Switch”.
The flashlight has the following levels, outputs and estimated runtimes.
LEVEL OUTPUT RUNTIME
Moonlight (ML) 1lm 191h
Micro (Mi) 10lm 91h
Low (L) 50lm 27h
Medium (M) 250lm 8h
High (H) 1250lm 3h
Turbo (T) 2800lm > 1000lm 1m+107m
Strobe (STR) 2800lm
Beacon 1s (B1) 2800lm
Beacon 10s (B10) 2800lm
SOS 2800lm > 20lm
This is the UI diagram taken from the Group Buy thread indicated above.
The names of the modes here are different from the ones mentioned in the table above which are the official designations taken from the user manual.
Here’s the explanation on how it works!!
TURN ON: from OFF, single click on Power Switch, it will turn ON in the last used mode (has memory)
TURN OFF: from any ON mode, single click on Power Switch
CHANGE MODES: when ON, single click on W Switch
> it cycles: Mi > L > M > H > Mi > L…
ACCESS MOONLIGHT (ML): from OFF, press Power Switch 1.5 seconds and release > in case the flashlight was turned OFF in ML mode, when turned ON it will start from there. The cycle will be: ML > Mi > L > M > H > Mi >…
ACCESS CONSTANT TURBO: from ON, press the Power Switch more than 1 second and release. When in constant Turbo:
a) single click the Power Switch to turn the Light OFF
b) single click the W Switch to leave turbo and start cycling Mi > L > M > H > Mi > L…
c) press the Power Switch more than 1second to return to the last used mode
ACCESS MOMENTARY TURBO: from ON or OFF, press & hold the W Switch more than 1second. Release to leave Momentary Turbo and: a) get back to the last used mode or b) turn the light OFF
ACCESS SPECIAL MODES (Strobe, Beacons, SOS): from OFF, press & hold on the Power Switch more than 2.5 seconds and release. It will first come into ML mode, and then advance to Strobe. When in Strobe mode:
a) single clicks on the W Switch will advance to other special modes: Beacon 1 second > Beacon 10 seconds > SOS > Strobe > … From any of these modes,
b) single click the Power Switch to turn the Light OFF, from any special mode.
LOCK: from OFF, press & hold the Power Switch for 8 seconds. The light will pass from ML > Strobe and the stops being lit up. Release the button and there will be 1 flash meaning that the flashlight is locked.
UNLOCK: when locked, press & hold the Power Switch for 8 seconds until the light turns ON in ML mode.
NOTES: As seen above, the regular modes cycle includes Mi, L, M and H. Therefore, ML and T are not in the regular cycle.
SIZE COMPARISON
As usual, I made some photos to compare the size and shape of the reviewed flashlight along with others in my collection here it is. And, as you can notice, even taking a 21700 cell, the TO50R is smaller than flashlights using 18650 batteries! Quite impressive, even knowing that we have smaller lights using the same type of batteries.
I just think that…they will not be capable of holding so much lumens for so long time as this one Big Smile
Livarnolux 314791 (2xAA) >>> WUBEN TO50R >>> Lumintop Tool 25
RovyVon E300s Angel Eyes >>> WUBEN TO50R >>> Acebeam TK16
RovyVon A8U >>> Klarus XT1C >>> WUBEN TO50R >>> Olight i3T EOS >>> Skilhunt M150
Emisar D4 >>> WUBEN TO50R >>> Lumintop FW3A
Amutorch VG10 >>> Zanflare F1 >>> Olight M2R Warrior >>> WUBEN TO50R >>> Convoy S2 >>> Convoy S2+ >>> Acebeam H20
Wuben Family:
T70 Camo >>> E10 >>> TO50R >>> TO46R >>> E05 >>> T1OR
T1OR >>> E10 >>> TO50R >>> TO46R >>> E05 + T70 Camo w/ 2 tubes
BEAMSHOTS
Much has been said about the TO50R beam and tint. It is probably one of the best I “tasted” and it actually makes this a flashlight incredible to use in flashlight or controlled lighting needs.
It is a very pleasant Neutral White beam, with no artifacts and no shifts. Althought it may look different in the photos, where the beam appears to be “rosy” in reality it is not, it is pure white!
Props to Wuben and _ the_ for making it look like this!
NO PWM
As mentioned before, this light has no PWM in any mode. Here are some shots above the LEDs, from ML to High. (It was in Auto, hence the small difference between the different levels)
Lighting down
A curisosity! When the light is turned off, the light dims slowly, it doesn’t shut down immediately. I tried to capture it in some different photos. As explained by _ the_ this fact is due to the good boost driver this flashlight has!
NIGHT BEAMSHOTS
Here are some night beamshots of this flashlight in different distances. It is NOT a thrower so it will not have a tremendous distance range. The floody beam is uniform and can reach a distance of at least 100 meters without issues, but it will loose visibility after the 75-80m, due to the floodiness!
In a distance of 30-40m it will lit up very well, and…it will show the true colours of things Wink
Distances superior to 50 m!!!
TINT COMPARISON
Here I make a tint comparison with other other lights I had around! All are multiple emitter lights!
Please note that depsite my careful taking the photos, it seems that it has some shift, it is due to my cellphone and the compression these photos suffer when uploading it to IMGUR Sad :FAPCEPALM:
Jetbeam RRT01 (3x XP-G2 S4-2B, Carclo 10507) > Wuben T046R (3x XP-G3 5000K High CRI, Carclo 10507 + diffuser sheet) > WUBEN TO50R > FW3A (3x XPL-HI 3D, Carclo 10511)
Acebeam TK16 ( 3x Osram White Flat, 10507 Carclo) > Convoy S2+ (XP-G2 S4-5A, Carclo 10511) > WUBEN TO50R > Emisar D4 (XP-G2 S4-3D, Carclo 10621) > Convoy S2+ (XP-G2 S4-3C, Carclo 10508)
WUBEN TO50R > Jetbeam RRT01 (3x XP-G2 S4-2B, Carclo 10507)
WUBEN TO50R > Wuben T046R (3x XP-G3 5000K High CRI, Carclo 10507 + diffuser sheet)
WUBEN TO50R > Acebeam TK16 ( 3x Osram White Flat, 10507 Carclo)
WUBEN TO50R > Convoy S2+ (XP-G2 S4-3C, Carclo 10508)
WUBEN TO50R > Convoy S2+ (XP-G2 S4-5A, Carclo 10511)
TO50R VS EMISAR D4 (V1)
A comparison with my other (and only) quad flashlight, the Emisar D4! Smile
As you can notice, the D4 has a slight narrower and throwier beam. Naked eyes, it has some rosy shift on higher levels and yellowish in lower levels (not completely portrayed in the “against the wall” photos).
And now, some Flashlight SexynessBig Smile
OVERAL APPRECIATION
This is, indeed, a great flashlight! Almost all the aspects are well achieve and make it a flashlight capable of competing with other major brands in this scope.
The machining, the robustness, the classy touch, the UI, the beam quality, the ergonomics, the driver efficiency and control, and the overall quality are pros enough to make this a very much appreciated flashlight for flashaholics that don’t like complicated stuff and UIs, for general public, for outdoor and indoor photographers, and for people that want to have a flashlight with powerbank function, as example.
However, there are also some aspects to be considered when appreciating, aspects that may be seen as “to improve”:
a) USB charging port cover – It should be more robust specially because as the included battery is long and doesn’t fit most of the chargers we have at home, it will be very used to charge the battery inside the flashlight. Therefore, it may result in breaking the cover or damaging it more rapidly, making it permeable to water and dust.
b) No glass lens – If, on the one hand, not having an AR Coated glass lens avoids tint shifts and makes the beam more pure, and the flashlight less longer, on the other hand a glass lens would protect the TIR optic from scratching. And knowing that this light will probably be used outdoor by many people, and put amongst other stuff, this should be considered.
c) The price – Even knowing that I got this light for free, and even knowing that there was a Group Buy for this light with reduced price, the MAP may be (is!) quite high. $150 is probably too much for many people to try this light, and that is a pity! This flashlight should be seen as an example to the great quality that Wuben puts in their lights, but if not many people are able to get it, it may be a drawback. In my opinion, this should be considered by Wuben marketing department.
Other than this, I do recommend this light to those who want a reliable flashlight, with extremely good construction and beautiful beam and balanced output!
Before I leave I will post some photos taken outdoor with the Wuben TO50R as source of artificial illumination.
These photos were taken by me and my girlfriend in the last weekend and even she was amazed about what this light could do! Next time I will take another light for her as well Hat
This is “the best” a flashlaholic can hope for Big Smile Crown
We now intend to make more night visits to gardens or green spaces to take some photos Love
Feel free to comment or to put questions!
Thanks for reading Wink
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
Edited by: MascaratumB on 11/20/2019 - 14:47
Pavlo
Last seen: 31 min 8 sec ago
Very few quads that use regulated constant current drivers. Kudos for Wuben to doing so.
Thanks for the review.
MascaratumB
Pavlo wrote:
Very few quads that use regulated constant current drivers. Kudos for Wuben to doing so. Thanks for the review.
Thank you Wink
Yup! Being powerful and regulated at the same time is quite nice to have and this light gives a nice balance of it! Wink
If I remember correctly, one of the reasons for the price of this light is precisely the driver and what it implies!!
OL Contest 2019
GIVEAWAY: 1 / 2
CRX
CRX's picture
Last seen: 4 min 15 sec ago
Nice review, thanks Thumbs Up
- LEDs & Other Stuff -  - UI CheatSheets -  - CRX Mods & Builds -  - Stuff for Sale -CRX Hand Made FlashlightsThe only place that fear can exist is in our thoughts of the future.
It is a product of our imagination causing us to fear things that do not presently and may never exist. Fear is a choice.
MascaratumB
Thanks mate Wink Beer
OL Contest 2019
GIVEAWAY: 1 / 2
EcuBebge
Last seen: 1 week 5 days ago
Thanks for the thorough review!
On my short list to purchase if it is ever available at a more reasonable price point. (unfortunately I wasn’t around for the GB)
MascaratumB
Thanks for reading!
Sometimes they are on sale here, by members that bought them on the GB! Check the WTS threads and maybe there is any to be sold Wink
OL Contest 2019
GIVEAWAY: 1 / 2
_the_
_the_'s picture
Last seen: 19 hours 34 min ago
Great and thorough review, thanks!
=the=
MascaratumB
Thank you and also thank you for the work in this light Wink
I mentioned it before and will say it again, I hope Wuben keeps listening to you in further projects because this light is, indeed, incredible!!
OL Contest 2019
GIVEAWAY: 1 / 2
id30209
id30209's picture
Last seen: 7 hours 46 min ago
Amazing review!
WTB Titanium 4sevens 2xAA tube
MascaratumB
id30209 wrote:
Amazing review!
Thank you Wink
OL Contest 2019
GIVEAWAY: 1 / 2
_the_
_the_'s picture
To clarify this design philosophy: Multiple clicks are reserved for quick repetitive single-click operations required in light painting (photography) – every click on the power button will turn the light on/off, allowing to quickly click-click-click-click through the scene (enlighten the places needed) without the risk of accidental turbo/strobe that would ruin the photo.
The same applies to the mode switch (W): Two quick clicks is always advancing two modes in the mode cycle, allowing you to easily jump between modes 2 and 4.
One of my favorite light painting artists Hannu Huhtamo (@hannuhuhtamo at IG) has been using the light for some time already and he told me he really likes the precision and control this UI offers. Please check out his work, it’s absolutely amazing! (and note that it’s all done in-camera – no photoshop!!)
=the=
MascaratumB
Thanks for your input on this _ the_!!
I guess my words may be badly interpreted regarding the “multiple clicks” Wink
When I mean that is so that people don’t think that we will have “double click for Turbo” or “triple click for strobe” !
Single or sequent clicks and press & hold is what we have in the light and it works perfectly, even for shortcuts!!
Also, thanks for sharing the IG of Hannu, didn’t know it and its quite impressive!! This light surely works well as light painting tool Wink
BTW, I forgot to mention one thing that I would improve, although it would imply changing some things in the UI:
> Although it doesn’t bother me much because I don’t lock the light electronically often, having to pass through Strobe to lock the flashlight is somehow awkward. I noticed it when I was testing the flashlight. Maybe using simultaneous press between Power and W Swithces (as the TO46R) could be a better option! Wink
Thanks again for your input!! Hat
OL Contest 2019
GIVEAWAY: 1 / 2
MtnDon
MtnDon's picture
Last seen: 58 min 12 sec ago
Great review! I/we have two of these and like them very much. Superb color rendition.
MascaratumB
Thanks Don! It is really incredible, specially outdoor Wink
Not having tint shifts in any levels allows greater detail and rendition as you said!
Glad you also like yours Wink
OL Contest 2019
GIVEAWAY: 1 / 2
MtnDon
MtnDon's picture
A couple of my photography “nut” friends really like the light output. People with experience in printing color photos may have an easier time in grasping color rendition. We were printing color photos at home on paper back in the 70’s.
Anyhow, I am continually amazed at how much better colors appear when walking at night with this light.
Watermanchris
Last seen: 2 days 17 hours ago
I have been wanting one of these and this review just made me NEED one! Thank you for putting this together. It is excellent!
MascaratumB
It was not until last sunday that I realized what this light really does in outdoor environment!
So I do get what you say! It is quite amazing to have all the colours bumping into your eyes naturally Wink
Hey, thanks Wink
I hope you can one and enjoy it as much as you can !!
This is a great piece!!
BTW, tonight I will try to show some differences between this TO50R and the TO46R that also has high CRI leds (XP-G3 5000K, bought in a Group Buy some months ago).
More than the amount of lumens, I’ll try to show how the colours get under the different leds Wink
OL Contest 2019
GIVEAWAY: 1 / 2
MascaratumB
The “Tree of Light” Blushing
(the broader context Smile )
OL Contest 2019
GIVEAWAY: 1 / 2
Scallywag
Scallywag's picture
Last seen: 1 hour 51 min ago
I’m still looking for one of these at a pricepoint within reach. Seems like such a nice light.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Watermanchris
I just broke down and bought one. Message Fin17 for a nice discount.
http://budgetlightforum.com/node/60338
MascaratumB
Hey, I hope you can get a nice deal on one, you won’t regret Smile
Maybe some affiliate members can get you a nice discount code Wink
OL Contest 2019
GIVEAWAY: 1 / 2
raccoon city
raccoon city's picture
Last seen: 11 hours 32 min ago
I'm glad you embiggened this photo.
It's very nice.  :THUMBS-UP:
MascaratumB
raccoon city wrote:
I’m glad you embiggened this photo.
It’s very nice.  alt=:" />
Thanks RC Wink
Well, at first I thought it should be smaller for people to click and see it big in another window!
But I realized the first one didn’t have the same meaning without the context!
It was a beautiful autumn afternoon, nature was screamming to be photographed Wink
Glad you liked it!!!
OL Contest 2019
GIVEAWAY: 1 / 2
wle
wle's picture
Last seen: 3 hours 15 min ago
wuben lights usually go down in list price, fairly soon after release
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
id30209
id30209's picture
wle wrote:
wuben lights usually go down in list price, fairly soon after release wle
I hope so cause 100$+ isn't my budget friendly...
adept1
Last seen: 1 week 6 days ago
Looks like a cool light, but the power button is an instant deal-breaker for me. I know it’ll be impossible to use in the dark with gloves on.
Currently owned lights:
Jetbeam Jet-IIIM | Jetbeam Jet-Ti M R2 | Solarforce L2M/L2P/L2T/T1 | 4Sevens Quark 123 | 4Sevens Quark Mini CR2 Ti | Solarstorm X2 | Convoy S2+ | Skilhunt H03 | Jetbeam Mini-1 | Amutorch AT40 | Emisar D4S & D4SV2 | Fireflies E07 | Lumintop FW3A
MascaratumB
Well, I tried it this morning with some gloves, and indeed it presents some difficulties locating the switch!
In that case, the best tips would be: a) put the clip in the front of the light pointing towards the switches or b) put it in the back diametrically opposed to the switches.
I also must state that the difficulty I had with this light, regarding to finding the switches in the dark without gloves, is no different from the difficulties I had with other lights under the same “experimental” conditions!
OL Contest 2019
GIVEAWAY: 1 / 2
