O-rings are not special, try your local hardware store or maybe ebay. Maybe even a rubber band.
Are you sure about that little white one? None of my assortments even get close to an band diameter that small.
When I bought the smaller battery tubes, they came with a couple of white O-rings for each.
I picked up an 18350 tube and it came without one. That was how I broke the first one.
I bought my from Lumintoplighting. Where did you get yours?
Direct from Neal.
When I bought some deep carry clip from Neal, I thought it was supposed to come with some white O-rings too but it did not. Either I got lucky with Lumintoplighting or Neal just doesn’t put them in the box.
No O-ring with deep clip from neal also. I guess it only comes with the short tubes?
Check out the discussion here if you’re interested in stiffening up the switch actuation.
Thanks, ordered them from amazon https://www.amazon.com/gp/aw/d/B000FMWLR8?ref=ppx_pt2_mob_b_prod_image
What kind of color is applied to the flashlight?
I’ve noticed the gray color coating is disappearing around the edges of the tailcap and bezel
I wouldn’t mind being able to get the extra hard anodizing, even though I think it only comes in black.
JaredM: Firelight2:I wonder if we can get more resistance in the switch by taking off the spring-steel dome on the switch and bending the 3 wings slightly inward.
FW3A mod thread. Post yours! - #1099 by JaredM
Heads up, these work like a charm, gives a good tactical feel.
Got my FW3A yesterday from the Amazon sale. I have a few new Sanyo NCR18650GA 3500mAh High Discharge BUTTON Top unprotected cells. After I inserted the cell from the head, the light briefly flashed to indicate contact. However, when I clicked on the e-switch, nothing happens, no light came up, holding down the e-switch doesn’t ramp up to down (no light came out at all).
I emailed Lumintop through Amazon, but haven’t heard back. In the meantime, I just remembered that I have some harvested flattop Samsung 24E unprotected from a laptop battery, so I popped one in, and the FW3A worked like a charm.
I plan to order some higher capacity flat top unprotected LG MJ1 to see if they work. So far, I think unprotected flat top is probably my best bet.
Order yourself a couple Sanyo 30Q’s
Some button top work and some don’t. The heights vary. You could remove the button top if your careful.
Sanyo? That would be Samsung.
I have noticed that the driver shelf has not been cut out completely on a copper version. This puts the driver out of alignment.
That’s normal. The notch on the driver fits there.
grin:I have noticed that the driver shelf has not been cut out completely on a copper version. This puts the driver out of alignment.
Doh that makes sense
That’s because the FWXX series lights are designed to work on unprotected cells.
I had to buy a large tweezers and tighten all the retaining rings on my FW3X V2s.
A few days ago, the switch started acting up on my FW3A bare. Today, I took apart the switch to find pieces of what appeared to be the flat black rubber spacer; not the nub. The pieces were not from the spacer in the light. I used canned compressed air to clean the circuit board mounted switch. The switch is now back to behaving.
Wish I would have checked the switch before I originally tightened up the associated retaining ring.
