RD new greatest power supply RD6006 DC power supply coming soon
RD6006 customer review
[To Ukraine in 20 days, delivery by courier. Packed perfectly. Happy with everyone]
https://www.aliexpress.com/item/32968303350.html
RD6006 feedback:
Specifically, RuiDengā€™s RD6006 is already similar to an adult device, but more important is the reasonable design - stick the power supply inside and close it all in one.
https://www.aliexpress.com/item/4000282551930.html
Another test:
thank you for making the test video
RD6006 review
[in general I really liked the design and functionality of the device.The package was packed firmly, there is one uncomfortable temperature wire for the battery(I didn't expect you to install the temperature sensor cable it this way)]
could you add our products link on the video :smiling_imp: :sunglasses: :smiley: ?
Can two RD6006 be used in parallel to achieve 12A?
no , it canā€™t , we donā€™t allow that , output must be isolatedā€¦
RD6006 power supply feedback:
as always, everything is fine, the packaging is beautiful
RD6006 customer feedback:
awesome made my month
RD6006 feedback from EEVblog
product link: https://www.aliexpress.com/item/4000282551930.html
Whatā€™s the advantage of this over a much more powerful DPS5020?
1.you can see the screen is bigger, we change the screen from 1.44 inch to 2.4 inch
2.the settings will be much easier because we add a keypad, if you want to set output value, you just need to spend a few seconds
3.add battery charging terminal, for more detailed information, you can see the videos on the youtube, we uploaded a lot
4.PC software has been changed a lot, now it is not only a data recorder, you can upload firmware for new function and use calibration function
as for other functions, it takes much time to introduce, you can check the product detail page or watch the videos
detail page:70.89ā‚¬ 20% OFF|Rd rd6006 rd6006w usb wifi dc dc spannungs strom abwƤrts strom versorgungs modul buck einstellbarer wandler 60v 6a batterie laden|Multimeter| - AliExpress
youtube channel:https://www.youtube.com/channel/UCy73jJ5-ZqhPzT7wJ6KTIaw?view_as=subscriber
set RD series and DPS series on the same panel
RD6006 link:https://www.aliexpress.com/item/4000282551930.html
The module arrived well packed. The size was smaller than imagined. The module was tested, all the main features and characteristics are in place. Special thanks to the developers of this device for removable fuses
RD6006 feedback:
Everything is super. Thanks. Packaging at altitude. Delivery to Domodedovo 20 days.
RD6006+S06A case feedbackļ¼š
I am very satisfied with the items, both.(waiting for your assembly)
[Perfect quality items. Great seller. Everything like in a description.]
[He came to Moscow in 3 weeks. The packaging is great. Initial launch successful. I did not complete the full test.]
[Great body! There are no dents, which is not surprising - the body in the foam is completely and wrapped in 3 layers of bumps. I recommend the seller. We are waiting for the last device - the 60 volt switching power supply itself]
https://es.aliexpress.com/item/4000282551930.html
