Colors are not confirmed. With that said, some of the discussed colors are almost certain to appear as Sofirn has expressed interest, but it might not happen for a number of months depending upon how well Sofirn can manufacture LT1’s and how many they continue to sell after the group buy is fulfilled. Right now I’m sure that they are focused on producing black LT1’s in relatively large batches in order to satisfy the existing demand (i.e. us).
I’d accept the black lantern if you want one right now, but you are of course free to wait until colors appear sometime next year (if they appear) as I’m sure that there will be tons of sales and coupons for the LT1 over the next year or more.
The above are my impressions and opinions from following this thread, so take them with a grain of salt. Any or all of it could be wrong.
The most difficult part of this this mod is that is small.
Smaller than what most of the hobbyist are used to, but not undoable
If you deal with anything but shady backyard electronics where your “soldering” skills came from sweating pipes at your uncle’s house or splicing wires in your can chances are that you will have something that will work to do it.
You know what I find hilarious is that some (including you) went through the effort to line up your bail with the switch.
Don’t yuck someone else yum just because you don’t like it.
I knew that usb c power delivery was gaining ground fast vs older charge protocols, but to a point where someone would struggle getting access to a regular usb A port? I wouldn’t thought this were going to happen so soon, not in 5 years at least.
AFAIK this lantern will charge with every single charger that is not power delivery exclusive and provides any voltage (within the input range) by default, no matter the cable. By default I mean if you connect a USB C meter to it it will read 5V. Almost all of the flashlights with dumb input works this way (no coding chip just a DC-DC converter). I haven’t received the code yet to test myself so I could be wrong.
USB-C is a physical spec. It is effectively defined by the connector and the fact that the hardware (connector and cable) can support at least 3A of current at minimum. PD is just ones and zeros flying about.
You can have USB-C chargers that are not PD. And it gets more confusing from there.
USB-C power meter need some power to run itself to it so it terminates the cable properly to get 5V. Same thing as USB A to C.
On USB-C there are no 5V on the VBUS until there is a pull down on the CC lines.
For me it is mostly a convenience thing. My tech replacement schedule worked out in such a way vast majority of things are USB C now. Phone, headphones, entertainment. So now if I go anywhere all I need is one charger and one cable to rule them all. Including the LT1
So actually, at least for me, finding USB-C chargers and C-to-C cables are easier to find as compared to A to C cables.
Now everyone on the list up to #1372 will be able to order 1 Lantern and after everyone on the list has had a chance to order 1 Lantern Sofirn will go back over the list and send codes to anyone wanting more than 1 Lantern.
Of course Sofirn will have to let us know if we will be able to order all the Lanterns we have on the list or just 1 at a time.
Great job by Sofirn on building a Lantern that the GREAT Team at BLF after much time and effort had Designed.
I was #62 on the list but have #377, #1047, #1048 and #2541 on the Wait List.
Hope to see some colors before the end of the Sale.
