Sorry, but sounds like bad advice. Turning it on for a few seconds will not build any heat. Even if left on max for several minutes it won’t do anything. Plus you risk cutting the wires which means more work to pull them completely out and extend them. This is all assuming the battery is removed. Cutting a led wire and shorting it with a battery installed could short the battery and probably burn up the wires. :confounded:
Maybe remove the battery, remove the wires from the star, tuck wires down in holes, heat the star with the iron, then try twisting. Maybe the heat will help soften the glue, but it’s unlikely. I think the heat will just sink into the flashlight body.
Local places are very limited in sizes. I typically order from China. Places like Banggood and Aliexpress have the best prices, but ebay may also be an option. Just figure out the size you need. N52 are the strongest.
From my experience, this is the best way to remove the LED MCPCB. I tried heating it up, but that did not help soften it up or ease in the removal. And it didn’t seem any type of solvent helped either. I tried isopropyl alcohol, paint thinner, nail polish remover (acetone), lacquer thinner, and naphtha.
It just took brute force twisting and turning the MCPCB back and forth to eventually loosen it up. And then I soldered a wire to the MCPCB to pull it out. The thermal adhesive seemed to be some type of flexible silicone material.
And in the end, the MCPCB took a beating, but I was careful to minimize any damage to the Boroit host.
Приветствую ! Драйвер на 4 АМС 7135 установил . Все работает . И память , и рампинг , и вверх и вниз .
Один вопрос : - это нормально когда сначала происходит кратковременная вспышка потом переход в память последнего режима ?
I don’t need that (yet?) but I’m curious about this setup.
I wonder why did you choose RampingIOS over the more-common Andruil. Do you simply like it more? Was it easier to port to this MCU for you? Any other reason?
ADDED: [Review] 77 Outdoors D25 Headlamp (18650) has some discussion. I’ll switch there.
My D20 arrived today and I’m very impressed with it. Well built, with fair lens, passable UI. Quite lightweight lamp with lightweight headband. Machining is quite poor and so is anodization.
Considering how cheap it is, it’s a great light as it is but it also seems like a great host.
The King of Budget Headlamps? Yeah, it looks so.
The description of the UI looks a bit scary with High or Low. Maybe that’s incorrect and it has 5 levels, but I would not take the risk. I found the motion sensor on the RJ02 a bit gimmicky anyway. I never used it. So I did not consider that light.
Thanks. I thought it would be a nice novelty to have, but upon further consideration I doubt it would last (interest that is). Much easier to buy an external motion sensor device & use a USB powered LED light source.
