To whom it has not yet been sent, it is necessary to write so that they send the flashlight with the corrected switch, otherwise it is necessary to refuse the purchase and return the money for the flashlight. Again, we probably need to wait 1 month until they fix it …
Ok so after some more trying belownis the best way to try to access the turbo.
First you do a full click to access the lowest mode or whatever the last memorized mode it was in
Then you do 2 half pushes ( no clicks) to access turbo. I think the trick is they have to be VERY fast - right next to each other. Older people will have issues doing such fast half-pushes one after the other . In other words a super fast double click ( double push)without the actual click.
I believe this only works from the on position. ( when the light is already on)
Yes you are spot on. This is how my sample is. There is nothing wrong with my switches. I have one sbt 90, XHP50.2, and flat white versions of this light. I have a total of 5 pieces of this light. The double half press will get you to turbo every time. It’s just hard to tell with our eyes. But I have a light meter, so I can confirm. But what I can tell you guys is the driver is CRAP. The memory is all whacked out. Sometimes it will remember the last mode, other times, it will go to next mode or previous mode. This is irritating. This defect goes for 5 samples. I went ahead and changed out the driver to the flat whites to make it single mode only. Sky Lumen did this mod. Dunno what he did or what driver he used.
I have no problem to activate turbo, however I agree that it can be hard when, for example, hands are cold. When the switch is released, there’s small pause before the light comes on. If you manage to half click in that time window, you’re in turbo mode.
I generally prefer lights without memory (starting on lowest mode) anyways. Is it at all possible to just disable the memory, perhaps at a hardware level?
Spaced the battery tube out with 2 copper sealing rings, cleaned all contacts with NO-OX, and on a 30T off the charger I got just over 25amps at the hit and 4710lms at turn on and dropping steadily… the tail cap and driver springs have some resistance they get a little warm around 30 seconds so does the light. The driver is a 3 FET with R010 resistor DD driver and the FET’s are scratched out but they look to be the SIR 404/800/Infineon style/type of FET.
Maybe try some Blue Gen 3 springs or just go for the 18awg bypass’s on the springs when I get the chance maybe this weekend…
Regarding the switch. Does the UI work the way it is listed on Neales website:
for SBT90.2:
Moon-Low-Medium-High
double clicks Turbo ,triple clicks strobe.
OR
Do you have to improvise like others have said, that is Turn it ON and then Two half presses for turbo. Supposedly can not be activated from the OFF position.
Here is what I measured with the Baby Blue LiitoKala (didn’t measure the voltage at the time) and I haven’t been really following this thread as of late… this is what I got…
1. 37lm
2. 505lm
3. 948lm
4. 1680lm
5. Dbl Tap - Turbo … (while in Turbo) Dbl Tap - Strobe
. It has memory so in lowest level, I double tap - Turbo - off, and repeated this Low- double tap Turbo off quite a few times and it never failed. I cycled thru the 4 modes many times, no hiccups. Got the light screaming hot, and repeated the above thinking maybe heat might make it wonky… never failed?
Can you try turning it off on turbo and see if it turns back on in turbo? When you do this, please check with your lumen tube, because high mode looks very similar to turbo mode. Can you do this 5 or more times
To be sure. All 5 of my samples have wonky memory. It will probably turn on in turbo mode three out of ten times.
How is that improvising? That's how I'd expect a reverse clicky to work. Either the driver memorizes turbo (to be determined I suppose? might be wonky) so you can access it from off once memorized OR, if it doesn't, of course you'll have to switch it on (full click) before telling it to go into turbo (double half-press/"tap"). A reverse clicky opens the circuit no matter if you fully click it or just half-press, to the driver it looks the same (it just loses power). It's just faster to half-press, hence probably many people have issues accessing turbo mode cause they're either doing full-presses ("clicks") or they're just not fast enough doing double taps - at least to me it sounds that way from the last few people reporting.
