“”They’ve lost their way from audio founding-father folks like Henry Kloss and James Lansing. And with headphones being so small, I wouldn’t be surprised if that segment is even more fraught with disinformation.“”“”.
Hey.
You want to listen to some real sounding music…
Try some early KEF Systems.
I had several starting with The Concerto’s.
B139Bass. with B110’s the mid’s),
With a T 27 topping them out.
Oak enclosures. lead or foam sheet lined. Bass Reflex.
Magic.
I ended up with a pr of Towers with Dual B139.
Dual B110’s and T27.
Reflex agin.
Custom tuned drivers and lead sheet lining.
7 ft tall 12in x 15in enclosures raised 2 in with corner pins.
on concrete floor. 210lbs each.
Driven with Leek amp’s And solid state turntable.
Still have most of my original reference LP’s. A lot.
Every spin on T-Table was recorded.
Back in the ’60’s they floated you off to heaven with Stravinsky.
Mahler. Sibelius. Jazz.
Music from the gods. Elvis wasn’t too bad either.
But no good for this modern electronics sound. Too slow.
I spent my youth in West Germany. UK Army,
att’d to UK/US Missile units.
We used to spend near every weekend up in the roof spaces of Deutche Factory’s listening to Ella, Dizzy, Satch, etc. Most weekend. Live.
The US military brought them all over.
All US music was free for all Overseas troops back in the ’50’s/’60’s.
Very interesting topic and the price at Drop is probably unbeatable!
Also very interesting to show how swapping resistor position can change mode sequence from LMH to MLH, MLH is my favorite but for the massdrop versions it is unfortunately LMH. I have always used the driver from Lumintop Tools for the Drop AAAs, of course this also works, but the tip here is cheaper
But I don’t buy AAA from Drop now because I already have too many with different LEDs
Thanks Jon
Yes, these are Preon clips made of stainless steel, fit perfectly and are more stable than the originals.
But they only fit Bezel down which I don’t mind
they also fit bezel up, so the light can be clipped to a hat
to make the light work in that arrangement, a spacer is needed for the pill to contact the body tube. It can be a bent wire from a paper clip, or a copper washer, or whatever you find works for you…
Thanks. Got it!
It also says that I have a $10 to spend on my first purchase of $50 or more.
It only seems to apply the $20 and not the $10. I was going to buy two to meet the $50 min and use both credits.
Also, no cart? You can’t select different items to get to a minimum value?
Nope, did not work for me (but I am a 20th century guy caught in the 21st century). Signed up with a Gmail email address and waited 2 days. Received other emails but nothing from them. So I signed up again with a period in the address name and waited three days with nothing from them. Just got the $10 off, no link for $20.
It worked, thanks to cyclops for helping out.
The same thing happened to me when I tried with an Yahoo email address and when I try with another Yahoo email address it works.
Try another email address or make a new email account.
