I got my FW3A TK edition in the mail today and went to work on it! I swapped in some LH351D, one each in 2700K/3500K/5000K. I have about a half-dozen FWxx variants that Iāve done some emitter swaps on but I wanted to do something different with this one. (Sorry for pic-heavy post!)
I picked up a SS bezel from Nealās and tried my hand at heating it with a torch to get some color. Itās a bit inconsistent and I heated it too much in some spots but overall Iām satisfied with the result! I also tried the same with the clip but I had a very hard time getting any color out of it. I assume itās plated, probably with nickel. I didnāt really feel like sanding and polishing it so I just heated it until it was glowing cherry red and ended up with a nice bronze color. Not too bad! Hopefully I didnāt weaken the steel too much.
I typically like to use drilled optics with trits but I tried it this way and I think I prefer this method. It looks much better from the front. I also swapped out the factory 10511 for a 10507 because I expected the LH351Ds to be quite floody.
Three different color temp 90+ CRI LH351D.
My other FW3xās have āFW3Aā printed on the MCPCB and the hole for the alignment screw is not drilled all the way through like this one. Functionally it makes no difference; itās just something I noticed.
FW3A TK edition; FW3T Stonewashed; FW3A OG Grey
Itās very difficult to capture the color of the emitters while shooting directly into the head of the light. This is about the best I could do after merging five exposures.
The LH351Ds under the 10507 are very floody. The hotspot is about twice as large as the SST20 with 10511. The LH351D hotspot has a very clearly defined edge where the SST20 blends smoothly into the spill. This might be due to the different optics.
The color temperature has a very cozy warm appearance with a slightly rosy tint. Unfortunately I donāt have a spectrometer, but I do have Cine Meter II and a Luxi sphere (calibrated). I canāt measure CRI but I can measure CCT and tint. Tint values seem to be on some arbitrary scale, but itās fine for making qualitative comparisons.
Here are the measured CCT and tint values for this light with some others for comparison. Tint values are given in amount of green, so more positive is more green and negative is more magenta. Measurements were taken at about the middle of the ramp, so 1x7135 for the FW3As (I never run my lights on turbo).
Maybe Iām wrong, but those shiny copper FW3Aās seem to be going away. I went looking last weekend and fleabay was the only place I could find them. Just checked, and it still says one left, same as when I ordered, but I ordered two, and the shipped notification email has arrivedā¦. Notice it is from Shenzhen.
The bead blasted copper didnāt seam to take off, you can still get them.
Maybe Iām wrong, but is that prototype FW3A V2 Lumintopās first production light with tritium slots? (assuming it does go into production.)
Edit:
It looks like itās got both a (magnetic?) brightness adjustment ring, and an on/off switch.
