Received my D4V2 Ti from hank last Friday, finally came into some 30Qs the other day to give her a proper test.
I opted for the SST20 4000K 95CRI LEDs with the flat retaining ring.
What can I say, this thing has some serious heft in the hand and pocket.
The images that pushed me over the edge were the purple auxilary LED shots with the illuminated stitch shining bright, Very very cool.
Been in the pocket for the last week, finally starting to see some colour change on the copper heat sync.
The supplied lanyard is a bit too small for my big hands to slip in and out of easily, Ill be opting for a larger one.
Low to mid power has a distinct yellowish tint until you get higher up in the output range, heat generation is very fast but as expected with an angry little pocket rocket.
I found myself using about 60% of its output most of the time which gave a nice colour tint with very minimal temperature output.
I wanted something with a very floody beam and a very high CRI for taking pictures at night while on urban explores, this thing rocks so far!
Thanks for your patience Hank for when I was repeatedly asking about a black D4V2, the moment I saw the Ti I pulled the trigger.
I also ordered the extra optic package which I am yet to try.
However, it should be noted that even the “green” SST-20 4000K 95 CRI still looks good at High and Turbo. However at lower power settings the green is really noticeable.
A brass D4V2 is very tempting, brass is my favorite material. It will be heavy so no chance to be my EDC, but still…
Hank, could you check if the almost 3 times (twice if measured with battery) as heavy brass version will still stick horizontally to a metal surface if I should add the magnet? (the picture with the knife shows it a bit tilted maybe for a reason? )
Hank is it possible to order the ti or the brass editions with the black switch cover, or no switch LEDs? If the switch LEDs are white they are going to be too bright for my bedside table. I like to have the red aux LEDs on low though, so that I can find the light in the dark.
Hmmm…I always order too soon. The D4S got Andruil the day after mine shipped, and now the one thing I didn’t care for on the Ti gets an upgrade just after I get a shipping notice!
Seriously, it’s awesome that things are always getting upgraded!
I think I still like titanium a little more though. Titanium may be heavy compared to aluminum, but it really holds up to abuse, it works well with a pocket clip, and it looks really good with the cool white lighted switch. One of these days, I should probably order a titanium one before they’re gone.
I know it’s not everyone’s first choice, but I still think the XP-L HI 5000K versions are the best.
