I just checked to make sure I wasn’t creating any FUD.
But you can lock the light out by unscrewing the head just a 1/8 of a turn.
Unscrewing the tailcap does nothing.
Thanks!, thats another good bit of Tool Lore, with several features…
1. If I unscrew and retighten the head, while the light is switched ON, it will advance modes too, no FUD!
and,
2. if I turn the light off at the head instead of the tailswitch
Next time I tighten the head, the light will be ON (no memory)
and
3. If I only unscrew the head a little, I can press the head to the body, for momentary on (which I hate, as this also turns the light on in pocket).
Is it a Feature or a Bug, when a Feature Bugs ME?
I unscrew more than a little, to defeat the undocumented, seldom mentioned, momentary on, feature/bug, that all twisties have. Even the infamous Fenix E01…
but I digress
now back to the Tracking Update on my CU Tool:
Hello Copper Tool,
Your item arrived at a shipping partner facility at 12:00 am on November 24, 2019. This does not indicate receipt by the USPS or the actual mailing date.
I bet it gets here in time for Xmas
And now for some Real FUD
If you dont buy the CU Tool NOW, you will NEVER get a chance to buy it at this price again… lol lol lol
I got the high CRI version of aluminum. I hope the output on medium is high enough for my intended use. High doesn’t last very long. The low CRI version tested 30 lumens higher on both high and medium, IIRC.
Can the pebbled TIR be obtained separately and inserted in any Lumintop Tool? Or is the internal arrangement different enough that reflector heads aren’t compatible? And if not, is it feasible to remove the OEM glass & swap with pebbled lens?
