Finally! A place I can come and vent about how this lantern doesn’t provide all the features that are included in the USB C spec. I’m mostly upset that MHL, Display port, and HDMI aren’t implemented correctly… I wanted to hook this sucker up to a projector! Forget about storing photos on it as well, it doesn’t appear that they managed to get that working.
It seems that if I use the included cable it will only work with most of the USB ports in my home, car, and office.
I have a bunch of USB-C devices and don’t even have a C-to-C cord yet lol. All of them have included C-to-A cables, so I wonder how many consumer devices are actually following the standard?
C is becoming very common in the US and the more sturdy connectors that aren’t uni-directional are a HUGE benefit and easily reason enough to not have micro-USB the way I see it.
Thanks for all of the info! Unfortunate that they implemented USB-C charging incorrectly, but honestly most devices implement it incorrectly so I think most people are used to that!
I think some manufacturers default to USB A to C for compatibility reasons. Many people have plenty of chargers and computers with USB A ports. The device itself could still support USB PD properly. And yes I know the obvious answer would be to just include both types of cables.
Thank you Lux-Perpetua, great diagram. I’m sure there are still some people who will whine about their USB-C purity but I simply cannot comprehend how this is a dealbreaking issue when the workaround is so damn simple.
Exactly. The LT1 was not designed, or intended to have the “fast-charging” high amp protocol, we only went with the USB-C type port for the durability and the fact that it can plug in in any direction. (easier in the dark) The LT1 is set to be charged at either the 1.5 amp default or set to a 0.75 amp charge rate to allow the ability to charge from weaker, low-amp power sources such as small Solar chargers, small power banks, lower power car & RV USB power ports, and so on. Unlike a phone, there is absolutely no reason that the LT1 needs a 3+ amp charge rate. even at the 0.75 amp setting there is plenty of time in a day to charge it when its not in use, also for the added benefit of longer cell life when being used in off grid situations where the lantern will be used every night & charged every day possibly, (365 days a year)
None of which have anything to do with the mistake in the USB-C implementation. No one is complaining that it doesn’t charge at 3A. They’re complaining that it doesn’t charge.
Any have an estimate runtime on the default step brightness for 3rd, 4th, and 5th (brightest) mode on 4 tested 3000MaH batteries? I just want to get a rough idea.
