Thanks. I hope they are willing to send a lens in a regular envelope for 4 bucks to the EU…
What size lens does the MF01 mini take? I have one on the way (SST-20 4000k).
And where does one buy such a UCL lens?
Tint on the 4000K is worse than I expected. Now I’m torn between trying to lower the DUV by swapping three leds to 2700K SST-20’s or swapping all to 4000K SW40 219B’s.
40.05mm x 1.90mm is what I bought
I tested the 2700K SST-20 in the E07 and I really like the tint. If mixed with the 4000K FD2, it should result in a very rosy tint.
Depending on the batch of SW40 you get, it might not even be as rosy as the SST-20 FD2 at turbo.
The target would be to get a acceptable (= zero duv or below) 200lm mode. I see the 2700K is in the BBL at that power, but the FD2 quite high above it.
Actually I don’t like rosiness at 4000K but prefer a neutral- slightly rosy tint.
From my experience 4000K on the BBL is a little yellowish for my liking. 4000K at DUV –0.002 looks much more neutral. 4000K with DUV of –0.003 to –0.004 for me seems perfect neutral white because I don’t see any yellow or pink unless I compare it side by side with another light of different tint. Maybe it’s my eyes or the ambient environment I’m in.
Can the battery sleeve adapters be gotten somewhere so that other cells can be used in the light
TIA
Chris
TIA
Chris
I just cut out, or rip out, a section of cardboard box to help center a smaller battery. If you want plastic ones, just check Aliexpress.
What other cells do you need?
Can the battery sleeve adapters be gotten somewhere so that other cells can be used in the light TIA Chris
I saw somewhere it could use 21700’s and 18650’s. I did not know there was a code for discount could I have one please?
Chris
Most unprotected 26650, 21700, and 18650 are supported.
I saw somewhere it could use 21700’s and 18650’s. I did not know there was a code for discount could I have one please? Chris
Anyone know of a coupon code I could use for the mini copper?
40mm x 1.9mm ucl lens fits the mf01 mini?
Sent. [quote=trailhunter] Anyone know of a coupon code I could use for the mini copper? [/quote]
Does anyone know how to turn the secondary brighter? On mine they are so dim I can barely see that they are on. I took the bezel off and looked at the pots but I don’t see how to adjust them, looks like a cage covers them preventing them from being adjusted.
Set them to High in the software settings first. Seven fast clicks from Off will cycle them Off, Low, High, Blinking. If the High setting is not bright enough, then you can try turning the pots. You need a small screwdriver.
Here is a pic of the MF01S.
There is no cage. If yours has a cage, can you post a picture?
Got one from banggood but it didn’t include a printed user manual. What should I do to get one, anyone in the USA can help me?
Digital copy might be more useful. Save to your smartphone for quick reference?
Also, it looks like there are secondary green LEDs but they don’t work (MF01 Mini - adjustment screw does nothing except for blue and magenta). Is this normal as the pictures show three colors?
The green only light up above 3.9 volts.
The 4th color is red, but they only turn on below 3.3v.
