I really wish it had a ramping FW on it… That light begs for it. Should be a compact monster, heat will be an issue. I really like the battery cap or what ever you want to call it.
I’ll try and help the best I can. I converted an M1 to a forward clicky. I have not seen the S12 in person and I don’t know how similar it is, switch wise, to the M1. Also when I did my conversion I used a forward clicky from MTNelectronics (for what it is worth I really like that switch and I’ll provide a link below). So with those caveats in mind, here is what I did that I would guess you would need to as well.
I removed the old switch and soldered the new one on. I then had to open up the washer just a smidge and I removed the nipple from inside the boot. I was recommended to use snips and not try and cut it out. I did just that and it worked fine. None of it was too hard. The switch I used was slightly tricky to line up and I had to remove it from the pcb it came on. I hope that helps.
An SST-40 in the headlamp wouldn’t have any advantage over the XM-L2 unless it was also driven harder. If it was driven harder, it would need to be a burst mode, because heat. The slight texture on the reflector is only going to cost a low-single-digit percentage of throw; I think what you really want here is a smaller, or dedomed emitter like an SST-20 or XP-L HI, and/or a wider reflector.
maybe so … Many probably need a long-range L-shaped headlight on a 18650 battery, and I think Convoy could do it … in addition, there are not many brands of long-range headlights …
But why do you want a long distance in a headlamp? I think headlamps are for short distances, just to walk or repair something. Not throwers. Maybe SMO reflector with XHP 50 or 70 with sliding diffuser. Not like in Skilhunt, but just sliding from left to right. I think this would be perfect. No, perfect would be to create headband with plastic holder like Armytek has. And that headlamp with strap would be just perfect. And XHP70.2 5000K Simon has, has great tint.
Looks like the Convoy BLF discount is no longer valid due to changes in the aliexpress website. The old method to apply it no longer works, and even after communication with Simon, it did not get applied before shipping.
It seems like bypassing AliExpress for custom orders is now the way to go… either there’s no way to defer payment and send a message, or it’s been made intentionally hard to find.
Aliexpress used to have an intermediate status between submitting an order and processing payment. This has been removed recently so the previous discount method no longer works. It’s not a big deal — I’m not going to waste everyone’s time over $2, I had just hoped to recoup the Aliexpress tax.
I think it is still there but hidden. I used it about month ago and had serious troubles finding it. I may have used a failed payment to get an unpaid order.
I’ll try to find the way on my next buy (Friday).
this is necessary when your hands are busy and you need to inspect the territory. Let’s say you have a machine gun in your hands and your hands are not free … In my case, there is one lamp on the handlebars of a bicycle, and when riding you need to inspect the territory at night …
It’s true you need throw whenever you are going fast. I usually am wearing a helmet when biking so a traditional headlamp would not work well. I use a convoy s2+ with XPL HI and smooth reflector that’s strapped to the top of my helmet.
I can't see the problem. You should click pay, then when transferring to your bank page to log in, just close the whole tab, then open new Aliexpress page and you'll see your order is "awaiting payment". It works for me, at least...
But I'm usually not camping with a machine gun...
But I get it. ;) I use headlamp only when walking. In forest I have a floody TIR headlamp and a small thrower. But if I got in the mountains, I'll get only headlamp to save weight. In this case it would be e.g Xtar H3 - so OP reflector and not throwy led. I think bigger led (like XHP70) + OP reflector would be perfect for me for everything. But I don't like combinations like XP-L HI and a SMO reflector. Too throwy.
EDIT:
So Simon, please make us a bit throwy headlamp with sliding diffusor O:)
