The eBay option method was originally to make an offer on the lantern using the GB price and placing your BLF user ID in a note. Maybe include the code you received as well. Then Sofirn should adjust the price, you pay and then they ship. But I canāt find the LT1 on eBay at present. Send Sofirn a PM and ask what to do.
A note to users of the LT1 that want maximum run time - use the lantern either on full WW or NW. Tint mixes increase the current draw by about 15-20% over either end of the tint range. Iāve not tried to characterize this, I just noted some observations in this post.
Code received in PM from Sofirn on Nov 26th ā¦ Code entered on Amazon US site for LT1 lantern without batteries, quantity one, ā¦ on the Amazon checkout page ā¦ āthe code that you entered is not validā.
I have used cut and paste directly from the PM and also tried manually typing the code. I matched case (upper) or not (lower), and included the dashes or not. Nothing works.
Pattern of the supplied code is AAAA-AA9AAA-AAAAAA ā¦ Alphaās, dashes, and Numerics only.
This is my first LT1 order and Iām not attempting to buy multiple items with repeated orders either. I wonāt complete the order until I can apply a code to lower the price.
Sofirn has been informed by PM and I have asked that they look into this situation further.
Anyone have an idea about what Iām missing? ā¦. Is anyone else having a problem with the first supplied code?
My code worked flawlessly, but I know of another German who had to get in contact with sofirn to sort something out.
I guess that they are very busy right now, and they will sort everything out eventually, but maybe not within seconds.
So I guess everyone having problems should clear that out with sofirn via PM.
Maybe we should have another thread for order-related issues, and keep this one to discuss technology?
Had my LT1 for a few weeks now, itās a great lantern. I was 303 on the list, mine had the bridged and badly wiped solder bridges, so I soldered all of them.
Iāve looked but canāt find the answers to the following questions:
1) Is the temp sensor on the main driver board or the LED mpcb? With all bridges soldered, the top gets fairly warm on the highest level.
Iām just wondering how reliable the thermal protection is, I know Iām running this hard on the highest possible mode so itāll generate some heat.
2) Iāve had rare instances of strobing when tightening the battery tube after replacing cells or mechanical lockout, it looks quite cool white- similar to the confirmation flash but obviously repeated at (guessing) 8 hz. Button unresponsive while in mystery strobe mode.
Iāve recently cleaned the +āve contact and not had any repeated strobing since, but as it was a rare problem, are there any other things I can try if the issue re-occurs?
3) This is my first true AndĆŗril lightso I have nothing to compare to- is it normal for the Sunset mode to progressively step down or is it supposed to be a gradual ramp?
I find the sudden steps a bit distracting.
On a slightly (un-)related note to sunset mode, I picked up some cheap 2xAA fairy lights the other day with a ā6hr on-18hr off, repeatā mode so that they come on and switch off automatically.
Iād probably use a similar mode on the LT1, especially with user configured brightness and a sunset ramp at the end of the āonā period.
Iād also love to see a tint ramping sunset (Bright, neutral white ramping down to dim and warm) followed by 8 hours of standby and a sunrise ramp.
Going to have to start to learn to code at this rate
ToyKeeper provided me a trial version of firmware to test that was attempting to fix a problem where short button presses were occasionally being missed. This version had strobing issues that could only be stopped by removing power. I never saw the strobing with the original build of the firmware sent out with the LT1, or any of my other Anduril lights. Wondering if the strobing just stops, or do you need to remove power to get the strobing to stop? For me power needed to be removed. Keep notes if you continue to see the problem and perhaps ToyKeeper will add looking into that to her ālistā.
Yes, this is how sunset works. I donāt know what step size the firmware uses, but in reality there are 150 steps from min to max. It seems like there could be smooth steps down for sunset, but I know the Attiny85 is very full, and perhaps implementing such a smoother step down function wonāt fit, or has not made it to the top of the priority list yet.
I also would like such modes, but I know the time keeper in the Attiny85 is not terribly accurate, and counting something like 8 hours would likely be pretty variable from unit to unit, at least thatās the way I understand it based on my recollection of hearing ToyKeeper discuss the Attiny85.
Ordered my LT1 + batteries a few days ago with the amazon code. Many thanks to DBSAR, the entire LT1 team and Sofirn for making it happen.
Today I realized that the current AE store price is under 57 USD (with the promo code) which is better than GB priceā¦ Oh well. Iāll just stick with amazon.
I donāt follow thatā¦. I paid Amazon 49.69 plus tax of 2.55 for a total of 52.24 US$ (LT1 only, no batteries. ) The actual advertised Amazon price was $69.99 and the coupon code gave a discount of $20.30 The only variance for a no batteries included LT1, shipped to a US address should be a possibly higher or lower sales tax amount.
