Noctigon K1 info / review
Pretty neat addition, the throwers in the Emisar/Noctigon lineup have been more interesting to me than the hot potatoes so this is nice to see. The cool white is a non-start for me though, but the samples of that LED I have seen have at least been very clean so should be quite nice for those who can tolerate such high color temps. I am curious how this would throw with a XP-L HI or XHP35 in it as those are available in nice tints and CCTs and realistically I can’t reliably see a mile in daytime for identifying anything anyway.
Nice work as always to Hank and Toykeeper.
The hole in the beam from such close distance isn’t from having a defective unit, that’s just how well-focused beams look at close range. Having used an Acebeam T21 and Maxtoch X Pro modified with Black Flat and White Flat 2mm accordingly, I can attest to that artifact.
The second graph doesn’t make it seem too regulated on highest output? Unless the second graph is with the warm room thermal regulation as well.
Available now with the Osram LED
https://intl-outdoor.com/k1-long-range-led-flashlight.html
There will be XP-L HI, SST-20 (good beam) options in the future,
for now, there are only W1, W2 options.
Order placed ! =D
Probably with a different cell like 40T, one that has more voltage on load will be more regulated than with the 48G cell.
It is already written in the review:
“This test shows a Samsung 48G cell, which is among the weakest 21700 cells on the market. A higher-amp cell would stay flat longer.”
Beautiful light, excellent design with tge built in USB C!
I will wait for the XHP35 version though, since it makes it a better all rounder.
4.9A for the W1, 7.8A for the W2.
But doesn’t a well-implemented regulated driver keep constant regulation regardless of cell voltage and resistance? Something like a Zebralight will make a cell that’s nearing 3amps still output turbo.
The graphs look like a direct-drive graph ie following the voltage sag of the cell.
No, you’re thinking of a boost driver which can step up the voltage from the cell. Zebralights use boost-buck drivers (which can both raise and lower voltage to maintain max efficiency), not linear.
It’s a linear driver (that basically converts the additional voltage into heat), unlike a buck/boost driver used by ZebraLight.
Well hopefully a cell with less resistance fairs significantly better, because that driver might as well be run of the mill fet+linear based on the graphs.
It’s not using linear regulators, but rather a FET + sense resistor for determining current IIRC? Like the recent Convoy drivers do.
The XHP35 HI versions will use a boost driver, as that emitter is only available in 12V.
Hank great job! Also ToyKeeper thank you for putting your amazing UI in another light. I think the lighted switch is awesome and the light seems very high quality. Now I need to decide if I go with the Osram leds or wait for something with more lumens…
You can think of the FET in this case like a variable resistor that adjusts its value so that it allows a fixed current to flow. And that’s a linear regulator.
Looks like a nicely designed light. Is this the first implementation of ramping FW in a constant current FET driver? It’s great that each mode is regulated, but if you don’t know the current at a given mode doesn’t that defeat some of the purpose of regulation? Like when you are out on a “mission” and want the brightest level without risking depleting your battery. For example I changed my mountain biking lights to 8x7135 drivers with simple 100–50… modes so I know I have the brightest light for a 1 or 2 hour ride.
Thanks for the review! Impressive thrower.
Does the W2 version use the same driver just tuned differently? I read people were direct driving this one and performed fine, so no need for a linear type driver?
Yours isn’t broken. I get the same hole in the center at very close distances in Convoy L2, C8 and P60 builds using the CSLPM1 and CSLNM1. Not sure why it happens, guessing it has something to do with the height of the emitter. But I’m probably wrong.
Here are the specs from Hanks sales link.
W1 (Osram CSLNM1.TG): 900lm, Lux : 650kcd
W2 (Osram CSLPM1.TG): 1400lm, Lux: 550kcd
I wish this was going to be available with the Osram at warmer (even neutral) tints. Is there any particular reason as to why the white flat isn’t or can’t be available at 4000-5000k?
