BLF LT1M - LT1 Mini (link to project)
190 posts / 0 new
DBSAR
DBSAR's picture
Last seen: 14 hours 26 min ago
Update,02,06,2020) -The LT1M-Mini has a project thread now, it is located here: >> http://budgetlightforum.com/node/71516
Update,01,28,2020)
Sofirm sent a couple host lights to work on designing a BLF LT1 Mini project from, one was a SP33, and the other was the IF25. after picking both apart, studying ideas, on boht of the lights, i came to the conclusion the IF25 is a great start host, as it already has tint-ramping, USB-C charging, and single 21700 or 18650 format size. I am currently designing & testing many head diffusers & shades ideas, and working to keep this smaller LT1 as the upfiring factory design, but with a very unique head i designed & am testing. stay tuned for the upcoming video of the birth of the LT1M, the more pocketable, hiker & backpack friendly compact Mini LT1 Big Smile
- Teaser photo below of the V1 prototype of the LT1M. I hope we can keep the price point of this smaller variant low like the MSRP of the original IF25 it is based from, and will have tint ramping, USB-C charging, and use the same Andruil firmware if we can shoe-horn Toykeeper’s amazing firmware of the LT1 into the Mini.
Update: 01/03/2020) i am awaiting for a couple potential hosts bases from Barry & Sofirn shipped out to me a couple weeks back, once i receive them i can work on the design & testing for the micro/Mini LT1.
Ok, i had a brainstorm on a LT1 “Micro” for those wanting something small enough to back pack.
I am looking to find a cheap 21700 host( or 26650) (with driver maybe, was thinking of a FW3A with the andruil firmware if i had one to sacrifice. A been doing some testing on a regular flashlight, but using a frosted lens internal reflector, to reduce hard lighting and a very unique shade/globe design with a dual-purpose shade design i been testing in secret, so it can remain with the LED firing up as it will be a single LED in the center, but still have very low side glare as most up-firing lanterns have.
It is planned to be a tiny Micro LT1, with a single 21500 5000mah cell,(or 26650) reduced amps draw, a 2700K or 4000K tint High CRI LED, built in USB charging, and small enough to back pack. Th only issue is it would be nice to find a host that has built in USB charging. I know of some 26650 lights that have built in USB charging, but cost a bit more than i can buy atm to sacrifice if for another lantern project.
Edited by: DBSAR on 02/06/2020 - 12:18
thijsco19
Last seen: 2 hours 23 min ago
I’m in! Big Smile
It sounds like it will be another awesome design!
Man Without Shadow
Man Without Shadow's picture
Last seen: 1 hour 23 min ago
Can you just make a lantern head that would screw onto an existing flashlight body?
When I'm spending mony foolishly, I like to do it wi$ely...
I have all the flashlights I need, but not as many as I want...
SammysHP
SammysHP's picture
Last seen: 4 hours 53 min ago
You mean something like this? http://budgetlightforum.com/node/70175
Btw. I have work on it in progress with better build quality and magnetically attachable shade. Most of it done, but not published yet.
staticx57
Last seen: 1 hour 6 min ago
Subscribed
jigsaw
jigsaw's picture
Last seen: 2 weeks 6 days ago
staticx57 wrote:
Subscribed
Do you know there is a subscribe button just for this?
Man Without Shadow
That’s even simpler than what I was thinking…I was thinking of a head with LED’s in it…but your idea seems less involved and more universal.
JordanZHP
Last seen: 1 hour 47 min ago
Yes please! 21700 would be great, not too large but capable of 5000mah.
dyates
Last seen: 5 days 16 hours ago
Sounds great to me!
Stittville Ed
Stittville Ed's picture
Last seen: 3 days 5 hours ago
Sounds like a very good idea.
You need to start a interest list to show how many light someone like Sofrin could sell
Lightbringer
Lightbringer's picture
Last seen: 3 min 33 sec ago
jigsaw wrote:
staticx57 wrote:
Subscribed
Up top…
reply   Mark as SPAM   Click to Subscribe   Report
djozz
djozz's picture
Last seen: 8 min ago
In my 18650 lantern mod I used a Philips bulb optic to spread the light coming from the underside. A similar optic could be used for this micro-lantern.
http://budgetlightforum.com/comment/1576561#comment-1576561
mr_magoo
Last seen: 17 hours 2 min ago
I have always wanted to have a real flashlight similar to the fw3a that was also a very good lantern at the same time, without having to reconfigure it. Like putting leds and a diffuser in the smaller diameter part of the handle that would radiate light either in 180 or 360 degrees depending in what you need at the time. Like for working under the hood of a car, or as area camp lighting.
That way you dont have to carry both a flashlight and a lantern.
I know there are flashlights like this, but not ones that are well done like your lt1 is.
I’m interested in your concept!
sunsethiker
Last seen: 3 days 15 hours ago
The dual color led from Sofirn like a good starting point for a base.
Gunga
Gunga's picture
Last seen: 2 weeks 1 day ago
I’m so in.
AguassissiM
AguassissiM's picture
Last seen: 21 hours 23 min ago
If this is the spot where we opt in for one then I`m in. Big Smile
***Rofis MR70*TurnRaise*Catapult V6*BLF Q8*BLF Mini*BLF Micro*Haikelite MT09R* Convoy C8*BLF D80v2 SST40*MatemincoX6S*AstroluxFT03-xhp50.2*AstroluxFT03-sst40*BLF-LT1*AstroluxFT03S-SBT90.2***
f0xx
f0xx's picture
Last seen: 2 hours 50 min ago
Looks like it could work
DBSAR
DBSAR's picture
That one is definitely a good candidate for a LT1 Micro base start point. Though with the tint ramping option that would increase cost like it did with the full-size LT1.
I was thinking of a single tint/single LED micro lantern with a good price point range of between 25 to 35 usd. (though a deluxe model could be designed to use that tint ramp option at a price range of 38 to 45 usd as that IF25 retails for now.
staticx57
Lightbringer wrote:
jigsaw wrote:
staticx57 wrote:
Subscribed
Up top…
Yes I do. It is more of a show of support to DBSAR
Man Without Shadow
Pick an existing flashlight, make some lamp head that screws on in place of the bezel…viola’!
Or is that stupid?
Just thinking with my “easy” hat on…
Dual purpose…flashlight for looking around, lantern for sitting around…
Fancy is fun, but when I backpack/camp…I only need just ANY light for night chores/going to the bathroom.
Muto
Last seen: 1 hour 18 min ago
In for 2 of whatever it becomes.
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
cu42
Last seen: 4 months 4 weeks ago
I AM 100% IN for at least a few of these after following the LT1 project!
I have been thinking about ideas for a mini/micro as well as the LT2 version, but didn’t bring it up as I didn’t want to distract from the LT1 before it went live. So, I guess, this is the start of the micro!
cu42
Or is that stupid?
I’ve been thinking on and toying with the same idea. I wanted something smaller than the LT1 and that could allow me to use a commonly available flashlight or something I already own to add versatility. Anything that would work with my favorite flashlight would be dual purpose and therefore increase the usability and value of mine or any current “favorite” flashlight. This would also save space and weight in a backpack if it would still function as a regular flashlight AND a well made lantern.
If the micro was planning to have an exclusive “lantern” UI and physical body hardware then the value of a standalone unit could outweigh the convenience of being able to use something already available and simply adding a well designed diffuser. It would have to offer a notable upgrade in UI and features not already currently available in an easily accessible flashlight. My thoughts were that a mini or micro unit may not need to be as feature rich as the LT1 or 2 therefore having more of a focus on the diffuser or reflector than the actual flashlight and UI itself.
A universal mount with a very pliable sealing/silicone ring or more firm adapters that could mount to different diameter heads to work with almost any flashlight might be widely appealing. With the focus on the diffuser and not so much the light body, it could have a more elaborate mounting and hanging option with variable reflecting/blocking shades and more.
A larger diameter cell flashlight (21700/26650) might be preferable to gain a larger base vs height center of gravity or a universal base platform might cover all diameters and add broader customer appeal. A base with a reducing diameter cone in the center could allow almost any diameter flashlight to be inserted at almost any angle to offer not only multiple diameter flashlight options, but also variable angles so light could be aimed almost any direction.
sbslider
sbslider's picture
I wonder if something like a FW3A with the right diffuser and a reflective cone inside would do a good job. The purpose of the cone is to block light from going straight up, and direct the light out the sides. For backpacking, weight is king, and the FW3A is a fairly light host that contains Anduril for an 18650 cell.
That said I’ll be interested to follow this project.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
DBSAR
DBSAR's picture
I been working on designing & testing a shade/globe design that does seem to work really good with a single LED that fires up in a small diameter shade, to allow as much light to shine downwards and 360 degrees without the up-firing eye-glare & lack of down light syndrome found in most up-firing lanterns, also this design has nearly no artifacts like the LT1.
The idea behind the LT1-Micro is to build a a small, slim lantern based with some of the features of the LT1, but simpler and lower costing, and small enough to pocket or sleeve in a backpack for backpacking, mountaineering, and camping trips where space & weight is a concern, but still have a lantern that can recharge off-grid via solar charger or power bank when on trips, have great run-times, great modes, (same as the Andruil in the LT1 full size lantern, a nice warm single-tint high CRI light, but with a dual ability (table lantern & hanging area light bulb)
I have built and modded many small, pocket sized lanterns for quite awhile, (video of those coming soon) but to have a consumer marketable micro-LT1 (and later possibly a mine mid-sized LT1) for those wanting a tiny lantern version of the BLF LT1 for backpacking, canoeing, kayaking, mountaineering, and any purpose a small, pocket sized version would be a benefit. While the current LT1 beats any other full size (and bigger) consumer lanterns on the market, there is still a lack of a small pint-sized lantern on the mareket too, and this LT1-Micro version can fill that gap. Cool
fourbyfive
I have used a variant of this camp lantern for about 12 years now.
http://www.blackdiamondequipment.com/en_US/headlamps-and-lanterns/voyage...
It has high function, is utterly dependable, easy to use, and goes for about a week the way I use it, on a set of 4 AA batteries. What it lacks is rechargeability, and use of lithiums. I’ve not tried sinking it in a pan of water. Notwithstanding, I would buy a BLF version just cuz, though being metal (?), it would probably weigh twice as much.
sbslider
sbslider's picture
Looking forward to the video. Thumbs Up
Also thinking plastic should be considered due weight considerations, and also cost. Assuming reasonable durability, but the lighter it is the less force acting on it to cause damage.
qandeel
Last seen: 12 hours 44 min ago
Sounds interesting. Is there an interest list yet? Silly
 عُمَانْ
Man Without Shadow
I’m 4054 on the group buy list…when will I get my code?
Kindle
Kindle's picture
I’ll absolutely pick up 2-3 if it gets made.
Or is that stupid?
Not stupid at all.
Review: Solarforce Lantern Converter
Big Smile
I never got around to grabbing a Solarforce LT-1 but I do have the similar one from the T4 kit.
raccoon city
raccoon city's picture
Last seen: 9 hours 25 min ago
I'm very interested...
A BLF LT1-Micro sounds great!
By the way, I would much prefer a 21700 host to a 26650 host.
