Wow. I could make a lot of magic smoke with that battery pack. Looking forward to seeing your creation evolve.
Also looking forward to seeing your entry glad you are entering!
Thanks for the encouragement everyone
Added some goals
My Goals
- Build something that I need and will use, not a shelf queen. It’s not a win if all it does is look pretty for the camera, then go to storage.
- Outperform expectations on 3D prints. The internet is filled with pics of 3D prints that look like they belong in a dollar store. This won’t be one. I promise.
- Inspire others that only have a 3D Printer to join in next year’s Old Lumens competition! That’s the spirit of this competition, to get people involved and building.
- Follow the basics of good design. Mind the weight, cost, and labor needed. I might want more than one. Maybe BLF members will want a parts kit? Like #3 said, I want to inspire.
Cool!
Way to go Josh.
Checkpoint
The CAD model is in no way nearing completion, but I need to check fit and function before going too far. Making changes to the foundation of the design at a later date can totally break the models. Ask me how I know.
It fits a bit loose, so I will be adjusting some measurements by feel. But overall it’s quite good. Onward!
The average voltage coming out of a 30Q cell when discharged at 15A is more like ≈3.35V, this means the average continuous power delivery rating from such pack is ≈500W, no more.
Interesting to see such an odd project, I like oddities. :-)
Good work i like it a lot. 20 in parallel could give you 10-12kw. Nearly enough to fire my brewery until the genset can take over.
It is a bad-ass little pack
Do you have a pic of your brewery somewhere? It sounds interesting.
World First!
I decided I wanted individual cell monitoring to alarm me if one cell in the pack reached empty before the rest. And I have some small pins that are perfect. To my knowledge, no hobbyist has ever made a fully functional 8 pin Dewalt-compatible dock. Until now. It wasn’t easy cramming all that geometry into such a tight space while leaving room for the .4mm print nozzle on the printer. But I did. Booya!
That sounds huge! Don’t get in trouble posting pics.
That’s some pro grade stuff there Grin
It was just a quick sanity check. I am planning a 200w build.
So, to clarify… This is compatible with the 20V MAX line of battery tools?
“individual cell monitoring” I’ll be interested in seeing this
I own genuine Dewalt 20v MAX batteries and genuine Dewalt FlexVolt batteries, and it fits them all perfect.
If anyone has trouble seeing images, please let me know. PM is good too. I’m doing it the most convenient way possible, but there are other options.
What is that?
That’s goals being met. The inside-out design is great. It’s light weight, has excellent passive cooling, and takes minimum print time and labor to assemble. There will be a “headlight” mounted to the left and right side. You may have seen or heard in my other threads that what I call a headlight is a ring I designed that mounts a CPU cooler to a tripod. In this case, 2 will thread on to the sides.
ooh, shiny!
Here are the headlight rings! The sanded/painted one sure looks more impressive than the unpainted one! This paint job meets goal #2. To “Outperform expectations on 3D prints”. It doesn’t look cheap now, does it?
