I see your point but I don’t get your use case. You’d need a hell of a long camping trip to have to recharge this light in a tent, and charging over USB is way less efficient than just carrying a spare cell.
My remark was more general about this style of USB port in flashlights rather than this flashlight in particular. I did reference its size though I meant more size than the flashlight.
Unless a new emitter option shows up I’m not buying K1 simply because its beam is too narrow for my uses. And in most of uses flashlight is the source of power for other items. And sometimes I charge one flashlight with another simply because it’s easier for me to carry spares in one size. Though that doesn’t happen too often.
Except that the grease would still make the items involved dirty.
I don’t want to sound like it kills the feature, it doesn’t. But this style of a charging port is now my third 4th least preferred after:
not having any port cover (strongly dislike)
having a cover that I may want to remove during use like (strongly dislike)
ADDED: non-USB port (forces me to carry extra cable) (clearly dislike, slightly less than the ones above)
This one I dislike.
And I prefer:
port on the cell (still a short risk but no grease) (I have mixed feelings)
a cover flap (may get lost but otherwise it works great) (like when quality is good)
After writing that I noticed there’s yet another way that I would really like but I haven’t seen it implemented.
Place the charger on the cell but deactivate battery pole while there’s USB cable plugged in (which indicates that ends are exposed).
The only problem with this is the proprietary cable. If you bring multiple lights somewhere now you need to bring multiple cables. Also what happens if the cable breaks? This is why the USB C standard is ideal.
Hank, would it be possible to order one with a different switch cover? Preferably black but really anything else then white would do.
Also it the switch you’re using still ALPS?
Eh, I prefer the good old take the battery out and swap in a freshly charged and place them in a dedicated charging bay. I don’t need extra cables and a good charging bay with a few spare batteries works better than having the light out of commission while charging. But that’s my 2 cents.
Oh I agree. I rarely use built in charging. It’s a nice addition for a non-EDC, as long as it doesn’t hurt waterproofing (like Hank’s design on K1). For a EDC I don’t want built in charging, just makes the light bigger.
Thanks TK, nice write up. And thank you Jordan ZHP for the heads-up, ordered the grey one with a 1x1 White Flat for ultimate throw. Didn’t realize just How MUCH Bigger it is than the D1S until I located this thread though. Love it! Can’t wait to see it in hand.
First light I’ve purchased in a while, may or may not use the C charging but at least it’s there in a pinch.
It sounds like you’re getting the best one. If you’re getting a thrower, may as well make it throw.
I didn’t think I’d use the built-in charger, but I’ve found it really useful so far. It can charge at 2A, and my only other 21700 charger maxes out at 1A. So it has been pretty handy for reducing the time between runtime tests.
Once that’s all done though, I might stick with the external charger for the simple reason that my driver isn’t glued and I don’t want to risk breaking any cables or connections by unscrewing the handle a lot. But this wouldn’t be an issue with a production unit.
Anyway, it’s nice having something with a beam similar to a GT but small enough to actually use.
Someone convince Hank to make a tail switch accessory and I might have to buy one of these - I know Anduril already supports dual switch layouts, and the flashing pads will make firmware modifications a breeze.
Thanks for the review Toykeeper.
It is noticeably bigger than the D1S, but performance is top of its class and makes lights like the BLF GT a little obsolete.
Looking forward to see the specs of the Boost driver version with XHP35.
I’m really eager to see the specs of the boost driver performance. I think driver efficiency is a neglected attribute in the enthusiast market lately, especially in small lights where heat matters (not that the K1 is small or prone to overheating). It may end up being hard to pick between SST-20 and XHP35 HI.
FWIW, runtime tests are still in progress. I’ve added some results to the graph, but I’m still adding more as the tests finish.
It may be necessary to shift-reload to get the newest version of the image though. Browsers might cache it even though the timestamp has changed.
Results are pretty much as expected — nearly flat until the battery voltage falls below the LED voltage, and then it slopes down in a shape directly matching the battery’s discharge curve until LVP activates, and then it stair-steps down for a rather long time until finally shutting itself off at 2.9V.
Even on a low battery though, just before LVP activates, it still makes 100+ kcd. So it out-performs a D1S or GT-Mini until the battery is at like 3% charge.
Nice! Thank you for the runtime tests. I just grabbed 4 more Samsung 50E batteries while they were on sale for $5 a pop. Might have to splurge and get this awesome light. Still having trouble deciding between the 2mm and 1mm. This is an awesome light.
Can we start a thread where we accidentally get drunk and buy things, recently by Hank, and mostly by Hank. I’ll update tomorrow when Elysia knows what I did. What’s wrong with us? Thanks FTK…
