I ordered the Nichia. Package just arrived. There are no marks on the anti-static vacuum bag that contains the light, but the plastic ācaseā has paperwork with āCree XP-G3 LEDā checked.
I loaded an Eneloop pro and initially thought the switch was DOA. I jumpered the tail and confirmed the LED was cool white (with a larger yellow halo around the hotspot than normal, which I donāt particularly like). Iāve since read that a capacitor in the electronic switch needs to charge for a few minutes, and itās working now. The literature says Click to turn On/Off; āPressā to select L-M-H. But I need to double-click while On to change modes. UI has no memory, it starts back on Low after about 2 sec off.
Rough measurements:
Low: 26 lux (0.02 A), Med: 82 lux (0.19 A), High: 440 (1.52 A)
If I keep this, Iāll definitely need to decrease the brightness for Low.
