Please could you make my life a little easier and (before you post your interest) can you check the BLF INTEREST LIST file (also linked to in post #1) if you are on the list already? Thank you!
I have finally decided on the design, and will start building the basic blocs for it. Should be ready after the final exams, so I can finally show it to the world, with a better UI and modified specifications.
A prototype would be good though, although I still need to learn some more C to actually build the software, and a 3D printer to actually make a physical model.
A 3D model is necessary to actually convince an OEM to build it.
