This post and a few after it give the final (for now) results of this investigation and updated FW build.
The build also adds the SOS function (after beacon in the blinkies group), and improves a minor bug that sometimes caused the firmware to miss a short button push.
Interesting. Thatās the first time Iāve heard of it happening on a light which doesnāt have an active standby mode (ability to blink aux LEDs while asleep).
Then again, I donāt actually have an EDC18 and I donāt know what firmware is used on itā¦ so I have no idea if it was modified. Iām just guessing that it wasnāt.
In any case, itās generally a symptom of some sort of physical issue which was bad enough to knock over the attiny chip. The ~8 Hz strobey thing is the flashlight equivalent of a Windows Blue Screen Of Death.
However, they could probably fix it by using newer firmware. Itās much harder to cause a reboot now, even with really noisy hardwareā¦ and if it happens, it does a normal boot now instead of going into the eye-catching āhey an error happenedā mode.
TK - this was a first-run EDC18 pre-order. Odds are high itās an older version of the firmware. Once I finish moving and get a place to work, Iāll reflash it and see what happens.
I decided to experiment with the āpencil trickā to see if I could enable an additional channel in my lantern. It works. Filling in the space between NW and WW pads for channel 6 increased the current at level 4 from 1.01A to 1.20A. 1.01*6/5=1.21. This would allow for folks to add channel 6 and/or 7 if desired without a soldering iron. It easy to remove with an eraser also. I already removed the connection in about 5 seconds per side.
Pencil trick - use a pencil to make an electrical connection between two pads on a circuit board, or across a component on a circuit board. In this case, I used a #2 pencil and applied a fair amount of pencil lead (what is this stuff anyway?) between the pads labeled ā6ā. The pencil lead is a āgood enoughā conductor to make a connection here. I donāt completely understand how it works, as I measured the resistance between the pads before and after adding the pencil lead, and measured about 10 meg ohms both times. But this connection is in series with the control line of the AMC7135, so there must be just enough improvement in the connection to allow the controller chip drive to reach the AMC7135.
I borrowed the picture below, but the pads circled in blue are 6 and 7 for NW and WW
Iām assuming these codes for the second batch are still ok for 30 days right? If I order now, chances are the light will arrive when Iām off on xmas holiday and might sit at the post office too long and they send it back.
Hereās a cartoon I whipped up for Sofrin while we waitā¦ā¦ (we all appreciate what you are doing!)
It depicts the anxiety of those of us that are on holdā¦ā¦ simply waiting for colors.
A ballpark ETA when Sofrin āthinksā the colors āmightā be available would be helpful and greatly appreciated.
If they feel it will be more than a few months, I will probably go ahead and orderā¦. I suspect others might also.
We can only hope the āstickā in the cartoon will get shorter soon ā¦.
Thanks Sofrin and Happy Holidays to everyone!
Yes, we have that message on a lantern ordered by a friend here. However, at the same time the order detail page shows the lantern has been shipped, since the 18th I think it was. There is a tracking number shown, however, since the 11th when the order was placed, the tracking number on the AE page has been showing āthe tracking information is temporarily unavailableā. The website 17track.net and any other tracking site can find no record. It seems to me that the shipment has never been shipped, but then I tend to be a pessimist about these things.
I would not feel so put out if the order detail page did not show the order as shipped. A more forthright admission of there being a problem and the order has not been shipped would make for better customer relations. Perhaps Chinese internet sellers have a different way of looking at customer relations than I do with my background in retail sales here in the US as well as Canada?
The GB code will not work in conjunction with AEās BlackFriday special. I am unsure how AE is able to even offer it at that sale price, or if they can sell it at that price. (maybe Sofirn can comment on that here
