There is no cell, that I know of, that has a continuous discharge of 45A for more than a few seconds. Iāve never seen one from HKJās, or Moochās testing.
But, I guess anythingās possible?
Pulsing, for sure.
Chris
Pulsing, for sure.
Chris
AWT lists their BURST drain ratings, not continuous no matter what the product page/packaging says.
They are straight up deceptive. For example the ā40A drainā 20700 they had was likely a rewrap of the Sanyo 15A continuous NCR20700B based on testing.
Did you even bother to read the review?
Craptastic.
OP doesnāt mention the cell, so his post is invalid.
Chris
Basically, if you purchased an AWT you got swindled. They do not manufacture batteries, they buy from whatever manufacturer and rewrap the cells with their own exaggerated ratings.
Shockli is also a battery rewrapper, albeit a lot better. You may find a Shockli cell or two a tiny bit overrated, just that.
Better if you tell us which cells you bought but in essence, nearly for sure the Shockli cell will work better than the AWT in every aspect (both more capacity and discharge rate/power delivery).
AWT = Ain't Worth Trust
So I sent back the AWT 26650 battery unopened. I do have the Shockli battery that seems to work just fine. I did some more research and I also ordered a Vapcell 5900 mah battery rated at 20a max continuous which should also be plenty to power the light. The Shockli so far will power the Turbo mode well beyond what the Sofirn battery will. I honestly just got this light to take camping with me and I want the option to take a couple of spare batteries so I donāt have to worry about charging them while Iām gone.
I have a couple of SP33 lights, but only with Sofirn marked cells in them. Your comments make me wonder if I should try something ābetterā. Being able to run two side by side with different batteries might be an interesting test.
amishbill, the SP33 is a flashlight with a fully regulated boost driver. Current and power to the emitter is kept constant at all times if possible. Current draw from the battery is affected by cell voltage input to the driver, this means it'll run a little little bit cooler with high discharge cells but since it is not a power hungry flashlight, nothing major. Current draw was measured at 5.8A from the battery when using LiitoKala 5000mAh cells (PLB INR26650-50A) according to this review, and a little less from a Samsung INR21700-30T due to higher input voltage. I won't mention the KeepPower 5200mAh, they rewrap many good cells but also some not so good others and they also overrate and overprice as a rule.
If you need some recommendation go get LiitoKala 26650s 5000mAh (affordable price and good cells) or the Shockli 5500mAh, which is a PLB INR26650-55A (a 1C capacity rated cell, this means it is underrated versus the usual 0.2C industry standard) rewrap and will provide you with the longest runtimes to this date.
There may be cells with apparently better looking figures printed on their wraps but as far as my knowledge of the market goes, it's all a bunch of lies (KeepPower rewraps the same cell as Shockli, only they overrate label it ā6000mAhā).
Cheers
Or how about: AWT = A ināt W ortha T urd
(Very similar to A.W.S.)
Needless to say, I wonāt be trying this brand & Iāll primarily stick to LG, Samsung, & Molicel, for the most part. I hear Sony is good though, but they all donāt make 26650 still as far as I knowā¦ Well I recently purchased two 5900mah 20A Vapcell 26550 batteries that are fairly new models for a Tomo battery bank which I havenāt received yet (and hope it fits in), but they donāt fit in certain vape mods or flashlights from what I hear. :cowboy_hat_face: Anyhow, thanks for the heads up!
If anything better has arrived, please post here; would be very interested to keep this thread going until we find something good that comes out.
Always Worthless Turd?
If you want good cells, with credible ratings, do pay attention to the Mooch reviews. He can get so technical with his methodology sometimes, it goes over my head sometimes.
A couple GOOD, trustworthy places to get batteries from: IMRBatteries and 18650BatteryStore
I personally always go for HohmTech and Samsung cellsā¦ Been eyeballing Molicel since they have been reviewing great by Mooch.
Both Mooch and HKJ offer worthwhile and useful information. I usually go to Henrik's site due to sheer testing completeness but I also check Mooch's reviews when needed, he offers higher power delivery/discharge rate testing.
I can understand that some of you just want high performance cells with cost being a lesser consideration, but as someone who does some battery pack assemblies my approach is quite different. To me, the performance versus cost quotient is paramount. This means Molicel, along with most cell rewrappers, is at the rear or nowhere to be seen in my (battery pack) cell wishlist.
I donāt think that has the āring and zingā to it that makes it so funnyā¦
Its gotta have the āAinātā LOL.
I like my version more.
Hey guys, whoās version do you like more? Can we get a vote going?
45A for 10 sec maybe, with some accelerated wear and or damage.
anything like that is for vapers really.
or it may just be incorrect/misleading/wrong.
the spec.
wle
Yep. Thereās our problem right there. Weāre not the market where the big bucks are competing.
interestingly, high drain is usually not possible with high energy storage
the designs conflict
so there is no way to know if a 60A battery would run the turbo longer than 45A or not
also there is no way to really verify either spec
these batteries should be rated like car batteries - cold cranking amps
as opposed to marine batteries which are rated in AH
they are NOT interchangeable.
wle
Not necessarily. The stuff has improved a lot, we now have high drain and high capacity in ways which were not possible years ago.
However, the way continuous drain rates (without temperature limits) are defined certainly pose certain restrictions to the maximum allowable energy in a cell because if not, its temperature would raise sky high without adequate cooling.
That is completely inadequate for li-ion cells. Also, cold cranking amps is as misleading as measuring an engine's pull ability by means of its torque, this is because what makes work or pull is power. And power is V Ć A, or rotational speed times torque.
If I am to design a LiFePO4 car battery given the continuous ratings of its cells, by the same CCA rating it would certainly leave the lead-acid battery in the dustĀ¹. This is because for the same amount of amperage the LiFePO4 battery would output higher voltage, or more amperage for the heavily depressed voltage the CCA rating is defined, which means more power.
Ā¹ Except in very cold conditions, it is said.
made you think, though
wle
