Nice start
subscribed!
Subscribed!
So my GF travel to Germany for the weekend and I had an opportunity to take over the living room and convert it into a workshop
I started to build the body. Since it it made out of 3 pieces of aluminum I decide to first attach the 3 pieces together using screws. It will enable me to precisely drill the 2 mm drills for the screws around body.
I did not manage to use the drill press before the pieces are screwed together so I had to drill another set of drills by hand
I tapped M4 to the bottom aluminum piece
And now I screwed all pieces together and can continue working on body but I have to wait for the next time I will be able to conquer the living room
Good stuff. You may find it easier to tap the holes with a battery drill, it is easier to keep the tap straight. Use WD40 or something similar to lubricate it.
I have lubricant in this green plastic. I also use it for drullind and sawing but never thought of using a WD40, maight be easier to apply, THX
You are in so much trouble when your GF reads this thread YuvalS. Love your style.
YuvalS Nice build. subscribed
Note: If you do not want oil on your projects, dish soap works just fine.
Good start
Nice room conversion Good to see you make a start
After the progress yesterday I wanted to continue working on the body after work. Unfortunately my neighbors are not big fans of me building lights at night (TBH they are also not like it when I build other stuff)
luckily, I have found a 220v outlet next to the road around my neighborhood, far from any building and was able to work there
As you can see I have took CNCman advice about using dish soap as a lubricant since it is easier to use when working outdoors
It was quit challenging to drill 12 2mm holes in a 5mm border but I am quite happy with the result, no drill pierced the side of the body and I only broken one drill bit
Perfect combo of will and "do with what you have" spirit !
That’s dedication. :+1:
What they said ^
Today I sawed the corners and turned the rectangle octagonal.
Unfortunately I forgot the jigsaw blade at home and the Dremel blade is too small, so I had to use a hand saw.
After sawing, I smoothed it all out using a file. The result is not perfect, but since it all done using only manual tools I am quite satisfied.
The body is finally take shape
You’re crazy mate
Couldn’t tell where you were this time
Looks like good work under less than ideal conditions.
Love the new workshop.
Thanks guys, it is the same workshop as previous pictures .
Looks like I will not change this place unless someone will kik me from there.
I am also using this spot to work on my camper car conversion so it is a busy workshop
