Which UI version?
25 to reflow to 219b sw30 or sw35
35 to reflow to 219b sw45k
Not sure what you mean UI version.
Is color aux emitters from Lexel TIR board?
Yes
How many emitters on board and what version is?
All FWXX lights have Anduril as the UI.
Maybe he means what is the UI of auxiliary board. It has a bit different UI by different version according to Lexel’s mode postings.
This is true……
12 emitters total, 4 emitters around each led. Look at my examples link. The board is his later version but with LVP+Voltage stabilization.
These are very nice. I have one with SW45Ks and Orange AUX LEDs. It’s my favorite light!
I take T+C-CW XPL HI with RED aux emitters. PM me for total and PP address. Thanks.
You wouldn’t happen to have some of those Bio Hazzard stencils for sale
No, I custom made it with a vinyl cutter and did an acid etch. Someone out on this planet has it, one of a kind
I need a good stencil maker again — I bead blast etch — Did you see the Yeti cup Vinh gave away with his Light Launch—I did that one for him
Well…… I suppose I can cut some out for you if you know how yo apply the stencil to metal. I could print 6 for 8 bucks shipped of you want it the size of what would fit on a fw3 button
Do you have a Cricket Cutter or something like that —- are the stencils self adhesive
Tc xpl hi sold
Anduril has been improved repeatedly over time.
Here, I saved this from somewhere:
Anduril firmware revision changes:
2018-12-14: fancy aux-LED (button switch LED) blinking mode (like heartbeat breathing effect) on BLF Q8/SP36
2019-05-22: 2-level lockout (4-clicks); momentary strobe mode possible (go to strobe modes before going to momentary mode)
2019-06-02: manual memory option (5H) ; button-release time-out is a bit faster
2019-06-27: factory reset function (hold button while tightening the tailcap)
2019-09-24: version-check function (15C) ; safety ramp-down if button held too long ; Emisar D18 & Astrolux MF01-Mini doesn’t have Muggle mode anymore (not fit)
2019-09-29: after safety ramp-down, also lockout the light(later Anduril versions will have the version check, so just do the version check to find out the revision)
Bump
