my mt07 copper behaves identically (sst20 4000K). Probably the regulation works much more efficiently as the battery voltage decreases. I wonder if the same problem occurs in the xpl hi version
I can’t believe so many solutions are focused on dissipating heat when this problem points toward an electrical sensor defect. What can we do to get relief from the manufacturer?
The sensor is inside the MCU. I don’t think all Atmels fail 8n MF01 mini and work fine in other flashlights. You can replace the MCU and got the same effect. So heat sinking is the solution or you need to redesign and remake driver pcb.
What other model shares all of the mini’s electrical components, but experiences no premature throttling?
What inadequate heat sinking theory explains DECREASED throttling during CONSECUTIVE max ramps, while temps INCREASE?
Recap: As the light gets hotter, it stays maxed longer … Maybe because the throttling is not heat-related.
If anyone has 2 batteries, with confirmed identical output, then they could test electrical throttling by heating the light with one battery through repeated max ramps, until it stays maxed significantly longer than the initial cycle. Next, swap that battery with the freshly charged one into the hot light and retest max ramping. If the light prematurely throttles with the fresh battery, then the experiment points to electrical throttling, not thermal?
the AMCs have also a thermal throttling, so they can’t get too hot, maybe that’s also a cause of the thermal problem
The copper/brass insert the forum member offers with technical drawings and CAD model available to me and I sent it to Mateminco with the request to update the lights
I already talked with them in the design process about proper heat sinking which got ignored in final builds,
the light was sold pretty quick to counter Fireflies 7x LED light without proper prototype sent for test/review and improvements getting to production model
I kind of hate the fact they changed your design and replaced that mosfet, inductor and diode and messed up that voltage measurement. “Value engineering” is reaching new extremes in china, they replace components worth few cents for ones worth few cents less not caring what the consequences will be… They often manufacture so many thing at the bare minimum requirements for functionality. Sad thing is it prevents them from gaining “brand loyalty”, which could in the end earn them much more. I asked mateminco for how much they would sell me a spare driver (for experimenting, flashing etc) they told me 33.5$/piece. When I asked them what the wholesale price is for 15 flashlights, they also told me 33.5$/piece (i was considering buying 15 flashlights as business gifts to emplyees). They literaly sell driver board at the same price as full assembled flashlights. Not very modding comunity friendly…
Samsung 40T starts off barely higher for only a tiny bit, then the Molicel beats it by a pinch the rest of the way and can go higher amps without failing (future proof).
It would be better to write him a message directly if you need answear fast. But very likely he will have to ask them, so you might as well ask them yourself.
OK If I get the news, I will let you know.
I contacted Mateminko and asked if they plan to put this copper washer on new lights (new batch).
I received an answer from them:“We are thinking about it now”
And then I wrote to them:“After you make the final decision, please let me know.”
