Yes its ready. Ships by Dec 15th it says. I was literally on his site last night to order a D4V2 for myself since my V1 has been acting up lately after a year and a half of EDC. The K1 wasn’t on there last night. I popped my head in here today after a absence and saw the posts on the K1. Immediately went back and ordered one as of about 5 minutes ago. I was doing so good too. The D4V2 was supposed to be my christmas present to myself, now Ive had to rationalize that Im replacing my V1 because I need to, and the K1 is my gift this year hahahaha.
Ordered in Dark grey, W1. My D4V2 is in sand with all the options including raised bezel since Ive torched a few pockets and a nice jacket hem because Im too cool for lockout. Damn you all for feeding my addictions! I had told myself I didn’t need a thrower and last night the D1S wasn’t on the site anymore or I would have ordered one also, and still ended up with a K1 today.
I’ve been watching this thread with interest……I’d appreciate some advice on whether the K1 would be suitable for me.
I don’t have a thrower flashlight at all and I like the idea of having one just to play with. But one specific time I’d use it is for confirming that no members of the public have entered the rear safety area before starting large electrically fired firework displays. A typical distance would be something like 200 metres depending on the products being used. I’m not expecting to illuminate the whole area……just swing the beam over the periphery for a final check.
Would the K1 be too throwy for my situation?
Which of the two LED’s currently offered would be best at that kind of distance?
The W2 would be better for your use but 200M is still too short. I recommend you get the Nightwatch NI40 with the SBT90.2. It has a very large hotspot yet throws very well. The large hotspot allows you to scan much easier.
I have a blf gt70, had a GT , and a gt mini VN.
The GT did a good job on the park by my house, 300 yards to the stores on the other side. The GT70 does an incredible job in terms of throw AND lumens downfield. PLUS great spill for people spotting…
The GT miniVN, a bit less of a thrower than the K2, does ok at 300 yard with zero spill. Not sure how the K2 will be but I personally would want a GT70 or something. the park is 14 acres, ranging from 150 yards to 300 yards across from where I stand. With the GT0 a sweep would be unescapable….
maybe you can try to do this test again but measure the output of the lights with a luxmeter to substantiate.
The left beam looks dimmer, but usually CW tends to be more visible, which isn’’t the case now.
The beam intensities were the same as measured with a lux meter.
You say CW tends to scatter more, but this experiment and an understanding of the scattering mechanisms show otherwise. That’s sort of why I’m bringing it up again; maybe the common belief that CW scatters more is just not true in most cases.
Call me stubborn, but i’m not convinced.
It looks like the total Lumen output of the right hand side is higher. (It must be, because the illuminated area is larger)
A real side by side test involves equal testing.
2 identical s2+ lights on the same brightness level, with proper lux readings and with identical LEDs but different tints.
Fair enough, but what exactly is your stubborn belief based on?
You are right that the total output of the warm light must be higher since the beam intensities are the same. This could be the reason why the warm light actually appears to scatter more in this photo. Although the beam is the same intensity, it is wider which would mean more scattered light in the beam cross section. However, I think the photo dispels the myth that cool white scatters a lot more.
I’m not trying to change anyone’s preference. I usually prefer neutral around 5000K especially when used outdoors. I just seek the truth; there’s no reason to use incorrect reasoning to justify one’s preference.
I just jumped in to say, that the 4000K SST-20 tint choice for K1 is amazing.
I compared it to an Astrolux MF02 (XHP35 HI 4000K), and of course, it has a bit narrower beam, but goes almost to the same distance.
For me, it feels like a complete replacement for these reasons:
- 230kcd is already very impressive, considering, that I chose a 95CRI tint
- 95CRI is well noticeable over the 70-ish CRI of the other flashlight beam, it is just better to look at the beam
WAY much lighter and more portable
Also, jumping from the top of the ramp to turbo makes the CCT several hundreds K ‘cooler’. I’d say about 4100-4200K for top of the ramp, but it feels like around 4600K-4800K in turbo (no measurements, just guesses).
Again, this is amazing.
I already purchased a phosphor converted (wider spectrum, somebody said, pale) green K1, as I could not resist.
I just wonder, if there could be a good (high intensity) phosphor converted amber, or similarly, a very ‘warm’ CCT (preferably under 2200K) white, as it could be also a very special thrower.
For people preferring a bit wider and more powerful beam (and being less bothered about heat), a 3500K 90CRI XHP35 HI option could be also welcome.
In another thread, I made a request for that, because I saw, that Osram has also this kind of emitter. So as soon as I happily noticed the adition of the choice, I did hit the red button already on a K1, and started awaiting delivery :partying_face:
I also wanted a flashlight with a phosphor-converted amber led. I ended up buying a custom D4V2 from Hank with Osram KY CSLNM1.FY Converted Yellow.
I like it. It seems to be warmer than my E21A 2000K R9050, but I did not do any measurements. I use it with 10623 optic, because 10622 had some artifacts in the beam.
