5-pack of 10x10x1 mm pills is $4.58 but shipping is $7.68. Not much more than a 2-pack (of unspecified size) from veleno.
I found also http://zoflex.com/products.html
They sell sheets.
Small sheet 152x152x1 mm is $35 + $11.5 shipping.
They have also larger sheets (304x304), 3 different thicknesses (0.5, 1, 1.5 mm), 2 hardness choices.
There are a few light makers that produce QTC flashlights:
Veleno
Peak
Fraz
I’ve seen a rumour that Acebeam 10160 uses QTC to
Myself I love QTC, it’s extremely simple and works great. I like this from-firefly-to-turbo adjustment better than any non-e-switch UI. And e-switches come with a few issues of their own, especially if one wants a really small light.
Thanks guys. Cool stuff indeed. It’s the first time I’ve seen/heard of it. I can certainly see the appeal of it, at least for lights using batteries that don’t have over-discharge issues.
I was interested so a little more googling shows that “Velostat pressure sensitive conductive sheet” is available from many places such as Tinkersphere $3.99 for 12” x 12” piece. Same stuff available directly from Adafruit, Digikey or Amazon for slightly more. Same properties as QTC???
As I remember from Match the only hitch in using this was getting it to stay at one setting. Need some kind of detent to hold the pressure steady.
Isn’t this possible to make yourself?
I mean like a piece of plastic sponge, soaked with graphite and latex mixture or something?
(i guess i should try that myself ?)
I tried some QTC and then gave it away because afaict it only works in single mode lights that are battery crushers (no spring above or below the battery).
I do not own any battery crusher lights…
All my lights have a spring, so the QTC would not work.
I’ve tried qtc before. I prefer the reliability and feel of infinitely variable control rings but those lights are bigger than qtc lights. I would like to try making a non-battery crush qtc host one day, just for the challenge of it
I did that with a cooyoo 10180 light.
Separate battery compartment, the head twisted to compress the QTC pill onto a fixed stationary contact not the cell itself.
Yeah, I mean the light was stripped & heavily modified, just remembered it with pinks comment.
A slightly better way to implement QTC.
So you could have a sprung cell compartment and just the head or tail unit doing the variable thing without crushing the cell.
