BLF LT1M - LT1 Mini (link to project)
Yeah baby, someone has similar ideas to mine:
http://www.aliexpress.com/item/32760825307.html
[/quote]
I have one like that atm, its very finicky, flickers a lot, and has some design issues. (added to the radiation-blue tint and built in charger that charged a cell to 4.32 volts.
I would vote for a head with a reflector + a ring of (mid power) leds around it.
[/quote]
Bad implementation does not invalidate a good idea. :stuck_out_tongue:
I know, its just the quality of most lights of that style on the market need some major modifications or don’t work well at all.
I would support 21700…… because it means I can use 18650 protected cells! For those of us who only use protected cells, many 18650 lights are not useable…… FW3…. EDC18……etc but 21700 lights can all take a 69mm keeppower!
Would it be feasible to make it accept 2 CR123s in an emergency? It’d be nice to have a fall-back to those if one is out camping and the rechargeable battery dies. I already take a couple CR123s in a waterproof case for some other lights I have (that are currently running rechargeables) for “just in case”.
Also, I’d vote for more than just 1 LED (2-4?) in order to drive them at lower currents for more lumens. A few extra dollars up front for something that can run longer and cooler at a given brightness (vs a single LED) would be good. Either way, I’m excited to see this project.
Edited to add: I was thinking 21700 or 26650 size instead of 18650 which is why I thought of more than 1 LED.
21700 is the goal with the ability to use 18650’s with a sleeve. as a lantern, it will pull less amps than a high-powered flashlight with a turbo that only runs for a minute or less, as lanterns run continuously for hours on end, meaning it will likely have a low-volt protection like the full size LT1, and being a low-amp draw it can run nearly any type of 18650 from old weak laptop pulls up to a 5000 mAh 21700.
The thoughts of having the tube made just large enough diameter to handle a 3-AAA carrier has been thought about, in that case which would add that extra battery versatility of even fitting a basic 3-AAA series carrier in it for that additional option in emergencies to use alkaline or Eneloops. (but not to charge them)
That’s a good idea DBSAR, a 3xAAA carrier would be a good backup.
I discovered if the inside of the battery tube of the Fireflies PL47 21700 light was just barely half a mm larger, a 3-AAA plastic carrier from any cheap 3-AAA flashlight fits it and works with additional longer springs.
I like this idea, but I also dislike it. Flexibility is always a good thing, but what would be the result of someone having this carrier installed and accidentally / ignorantly plugging up the charge cable? Cooked NiMH or popped alkalines?
I’m sure it would be possible to design a mechanism that would prevent that, but it would complicate things.
…. a keyway, a switch that is activated when the 3xaa carrier is inserted……. everything and anything is possible. Is it worth the effort?
indeed that is a concern.
good points. Something to disable charging with a 3-AAA carrier in it.
Those carriers have a pogo-stick nipple to make contact, no?
Make a small center contact for power, and a concentric ring around it for charging. Should make contact with flat-tops, but not with the carrier.
good idea :+1:
Put me on the list for three. (When the list is started)
Would it be possible to add red LED’s operated as a separate mode in Anduril? Perfect for keeping bugs away when camping or fishing. Perhaps deep red XP-E? They are relatively cheap.
That would work, you could do a similar circuit to the yellow work lamps that take 18650 and AA, they have a series of diodes to prevent charging of the AA.
Big Clive has done a tear down and circuit
That way the LT micro could be a power bank too.
https://youtu.be/NAoISQaA5jY
it is possible, depending on if it will drive up the cost of the lantern or not.
Very Cool! I love battery versatility! Like the ZL SC80 and the CountyComm Single C and D lights that have AA and AAA carriers.
