Thanks for testing these!
It looks like somehow the 2000K was received in R9080 rank even though Clemence listed them on his site as R9050.
Thanks for the tests and happy to see they are as good as e21a!
Maukka, thanks for the test! What kind of reflector or optic did you test them under?
Added a CIE chart for quick tint checking.
Additional observation: mixing 2700K+4000K in different ratios would result in the 3000K or 3500K emitters almost exactly. Same goes for 4000K + 6500K which results in the tint for 4500K and 5700K.
Test was done integrated.
Output and Vf graph on the 6500K sample.
Anybody know what the approximate gain in luminous intensity/Throw is of the e17a compared to E21a under the same optic/reflector?
It looks a bit like a dedomed XP-E2 (low CRI) both in output and die size, but just a bit less, pretty good for a 95 CRI led.
So a quad e17a is about the size of an XP-G LED, and quad E21a is about the size of an XM-L LED.
Would you say the quad e17a will have about 40% more throw than the e21a at the same power setting?
Tint vs. current on the same 6500K version. Fast sweep with only 3 seconds spent on each step.
Hahahaha, thanks Maukka. Your post makes me giggles. The color swings for 3 steps R9080 is the tightest.
[Clemence]
I tested only 2000k and e17 has a very low lm/w. And, generally. you get same picture in narrow optic (a smalled spot and seeming increase of range). A only advantage of e17 series is a rosy tint at a lower current than e21
Thanks for the information. Could you tell me what optics have you used?
XP 20 mm x 5 degree with custom matted #320 sand and slightly cleared dichloroethane. Bottom of lens is cutted off to 0.3 mm ([GB ended,discussion only] CRI > 80+ NICHIA 2000K-6500K [E21A/219B/219C/319A/144A/757GT-F1(Optisolis)] - #475 by clemence GB 351D closed. - #100 by Bob_McBob). And i will be compared parallel 2000+3000k with 10x30 elliptical lens. I have it in e21 and, for me, throw is low as outdoor light. All optics is yajiamei
So if I am understanding you right your are using a lens like this(Page Not Found - Aliexpress.com)? Is it a multiemitter setup(VR16SP4) or single emitter setup?
Yes this lens. Maximum 2xe21 on vr16s1 (hole dia 4.8 mm). Very carefully when installing the lens, damage to the phosphor is possible
An quad system (vr16sp4) i do not use because i got problems with focusing and final output. My working hl have 2x 5000k with https://www.aliexpress.com/item/1281151114.html
Clemence,
Have you played with using the Green/Lime E17A in a tint mixing array in order to better track the BBL?
Has anyone gotten an E17a quadrix to fit in a 1 x AA/14500. Since I missed the Jetusolis GB, I want to make 3 Tool AA Quadrix setups - 1 each at 2000K, 4000K, and 5700K. I could probably file down a 16mm E17a board to 14mm but I’m afraid to damage the E21a emitters.
I have quite a few 219b R9080s in different tints (3000K, 3500K, 4000K, and 4500K)so that’s the backup plan but I love the range of tints and the ability to mix with the Quadrix setup.
Filing down a 16mm seems like it should be a reasonable solution, as long as you’re careful not to touch the delicate phosphor coating on the emitters while handling it.
I also remember Clemence saying something about being careful not to damage the ceramic insulating layers when drilling. I’d suggested making your filing motion mainly around the circumference, rather than up and and down.
1 x E21A would be an option, except the 10mm single emitter boards are out of stock, and if you’re using a 14500, that might be a bit much for the emitter.
