Would it be feasible to make it accept 2 CR123s in an emergency? It’d be nice to have a fall-back to those if one is out camping and the rechargeable battery dies. I already take a couple CR123s in a waterproof case for some other lights I have (that are currently running rechargeables) for “just in case”.
Also, I’d vote for more than just 1 LED (2-4?) in order to drive them at lower currents for more lumens. A few extra dollars up front for something that can run longer and cooler at a given brightness (vs a single LED) would be good. Either way, I’m excited to see this project.
Edited to add: I was thinking 21700 or 26650 size instead of 18650 which is why I thought of more than 1 LED.
21700 is the goal with the ability to use 18650’s with a sleeve. as a lantern, it will pull less amps than a high-powered flashlight with a turbo that only runs for a minute or less, as lanterns run continuously for hours on end, meaning it will likely have a low-volt protection like the full size LT1, and being a low-amp draw it can run nearly any type of 18650 from old weak laptop pulls up to a 5000 mAh 21700.
The thoughts of having the tube made just large enough diameter to handle a 3-AAA carrier has been thought about, in that case which would add that extra battery versatility of even fitting a basic 3-AAA series carrier in it for that additional option in emergencies to use alkaline or Eneloops. (but not to charge them)
I discovered if the inside of the battery tube of the Fireflies PL47 21700 light was just barely half a mm larger, a 3-AAA plastic carrier from any cheap 3-AAA flashlight fits it and works with additional longer springs.
I like this idea, but I also dislike it. Flexibility is always a good thing, but what would be the result of someone having this carrier installed and accidentally / ignorantly plugging up the charge cable? Cooked NiMH or popped alkalines?
Would it be possible to add red LED’s operated as a separate mode in Anduril? Perfect for keeping bugs away when camping or fishing. Perhaps deep red XP-E? They are relatively cheap.
That would work, you could do a similar circuit to the yellow work lamps that take 18650 and AA, they have a series of diodes to prevent charging of the AA.
Also thinking plastic should be considered due weight considerations, and also cost. Assuming reasonable durability, but the lighter it is the less force acting on it to cause damage.[/quote
I think going composite (plastic or something else) is the way to go. The cost of mold-making might make the project unprofitable however. I would think 5000 units or more would have to be sold to break out on it. Personally, I would not carry a metal flashlight on a backpack venture. As Colin Fletcher once said, “Take care of the ounces and the pounds will take care of themselves.” I cut toothbrushes in half and stuff like that. Nothing metal in or on my pack is how I go, if possible. I’m keen on the aaa batteries as a power option, or aa would be fine too. I can’t imagine carrying power bricks in a backpack.
As I mentioned earlier, I’ll buy anything with the BLF monicker because I like the looks and function of everything I’ve seen. If the mini lantern is too heavy for me, then I’ll surely find a use for it elsewhere. So carry on dbsar, I’m sure it will be cool. Check me for one at least.
